Question about HP Office Equipment & Supplies
The copier is printing with two lines going down the paper
    President:
  • HP Master
  • 990 Answers
Hello sir; Did you make copy through by ADF if answer is yes, then just need to clean th glass, otherwise you have to change drum blade or cartridge.
Posted on Oct 04, 2009
Canon 200gp copier is leaving black lines when printing.
you have to go into printer tools, printer head clean and follow the other instructions.
Jan 27, 2013 | Canon GP-200 All-In-One Printer
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
How do you eliminate a line going through each page
Run a 1/2 print test.
Put paper in the manual feed tray (tray 1).
Print something. When the paper feeds 1/2 way into the printer, open the top cover.
Remove the toner cartridge and look down at the paper. If you see the line, replace the toner.
If there is no line, then the problem is probably the fuser.
Feb 13, 2011 | HP Laserjet P3015X Printer
Hp932 off line print test?
press the paper indicator knob and hold it down for say 5 second you will see the power light begins to blink, insert your paper to print
Aug 29, 2009 | HP DeskJet 932c InkJet Printer
Problem printing with Dell 3010cn Laser
Check for damage to the fuser located right were the paper exits. damaged fuser can cause lines
Feb 10, 2009 | Dell 3110cn Laser Printer
Printer won't print out test paper.
you may try this
1) do clean nozzle cycle (do more times) until print normal, refill enough ink., not fixed go next
2) clean the color ink cartridge nozzles, put the cartridge down the soft paper damped with solvent or water, do it again untill to see three different color inkgo out on the paper.
Feb 08, 2009 | HP PSC 1600 InkJet Printer
Lines on print
check your paper guide and then run through it's maintenance test. then run another test paper.
Jan 05, 2009 | Kodak Easyshare Printer G600 Thermo...
Minolta 1030
Depends if the lines go across the page as if the paper comes out or if they go down the page. If across then poss drum, transfer, or fuser unit, If down the page could be a short on the charge then poss only drum unit.
Thanks Jason
Aug 16, 2008 | Minolta EP1030/1030F CS/PRO Copier
Prints Faint green horizontal lines
Go to control panel and printers and faxes and right click on printer icon then hit printing preferences, go to maintenance and do head cleaning cyles and print nozzle check. if it comes out fine trash and reinstall driver
download driver from support.epson.com site after selecting the printer mdel on the lists
Apr 12, 2008 | Office Equipment & Supplies
Unable to print properly keeps printing on one line
Sounds like there is something jammed in the paper feeder, or maby its the paper feeder itself. Check to see if the path the paper follows through the feeder is completely clear. Sometimes paper is left in the feeder from previous paper jams.
Aug 07, 2007 | Lexmark X73 All-In-One InkJet Printer
26 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
