Question about Garden
Blower will start but does not get enough power. when i give it full throttle, it cuts out.
2 Suggested Answers
Mentorcase
  • 5 Answers
SOURCE: model bp250 leaf blower, cuts off on full throttle
Sounds like its starving for fuel.
Try fishing the filter out of the fuel tank with a piece of bent wire,
remove of hose and back flush with carby cleaner a few times reinstill and see if it works.
Posted on Dec 08, 2009
Wont run at full throdell
Start it, give it full throttle, adjust the hi speed jet while at full throttle until you get max speed.
Aug 22, 2013 | Poulan Garden
Why does it idle fine and then when you give it gas it boggs down
A two-stroke engine idles because a very small hole behind the throttle plate lets a tiny amount of gas through to keep the engine running. At full throttle the air moving through the carburator pulls gas through the venturi vaporizing it. With the motor at idle, if you give the motor full throttle very fast the first charge or two that get into the cylinder are almost completely fresh air with vary little or no gas mixed in. It takes a revolution or two for the motor to pull air through the carburator fast enough to get a fully charged mixture of gas and air into the cylinder so you get full power. This effect is especially pronounced when the motor is cold, the gas doesn't vaporize as well when the motor parts are cold. If you give it throttle slowly or let it warm up the effect should go away.
Feb 22, 2012 | Poulan Pro PPBP300 30cc 2Stroke Gas...
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
My homelite might lite 26b will run in the choke position but cuts off in the run position. I have drained the gas and put in fresh gas, new plug and opened the carburetor and cleaned it.
if it seems low on power,remove the muffler and clean out all carbon build-up,if it has power as in full throttle,then the carb is still dirty and needs to be rebuilt
Mar 12, 2010 | Homelite Consumer Products MightyLite...
Was mowing starting cutting out and died wont start back it is flooding with gas.I cleaned the carb didint help
replace the spark plug first then go from there, try starting fluid if flooded but also as soon as it fires during starting pull back the throttle off choke sometimes you don't want to give the unit full throttle when starting 3/4 throttle is good enough
Aug 02, 2009 | Garden
My Ryobi weed trimmer is easy to start and idles great. It will not rev up high enough to cut. Only likes lower rpm. Sounds like it is only giving up about 1/2 of the rpm's as when it was new. Changed the...
If you have a spark arrester fitted, it will be blocked with carbon preventing the exhaust gases leaving. It will be behind a plate bolted to the exhaust silencer/muffler. Scrape the carbon off the wire mesh carefully, until you can see through the mesh again.
Apr 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Blower wont run at full throttle
Start with the spark plug it is the easiest.
But sounds like the carbourator is dirty, Probably fouled with old gas varnish. When it is idling give it a little throttle, flip the choke on and then full throttle. If it goes full throttle and doesn't conk out, it is a fuel issue.
Good Luck
Dec 07, 2008 | Troy Bilt Backpack Blower, 25cc, 160 Mph,...
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
