Question about GE Dishwashers
Dishwasher is not draining. Everything sounds right but it just doesn't drain.
  • 15,935 Answers
If this a new installation - check the knockout plug is removed from the garbage disposal.
If it has worked in the past - check the pump inlet screen at the bottom of the unit for clogging.
And if the screen is clear - and the motor is spinning - the pump may be damaged.(impellor separated from shaft or broken vanes etc)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 04, 2009
Doesn't drain out all the way water stays in
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 30, 2011 | Maytag Dishwasher
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
Kenmore dishwasher won't drain. Can hear motor trying to cycle but it sounds like it's locked.
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Hope it helps...
Jun 23, 2011 | Dishwashers
Water does not completely drain after a wash cycle. Everything else seems to work just fine.
Hi
Daniel
Jun 16, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
My dishwasher is not draining all the way where is the drain? Maybe it is plugged?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Oct 25, 2010 | GE Profile PDW8400J Built-in Dishwasher
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Oct 20, 2010 | Asko 1375 Dishwasher
Hi
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
Standing water in dishwasher
Hi
Oct 19, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
52 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
