Question about Toshiba Satellite A135 Notebook
Safe mode help
Hi again...well I tried the 1st solution given back on my problem of safe mode. going to F8 brought up the boot menu, I arrowed to start normally and entered. Still started back again in safe mode. Pls. anyone with another go at let me know asap. Thanks a bunch!
  • 205 Answers
Check this:
Start->Run
Type msconfig in the box and click OK.
On the General Settings Tab make sure Normal Startup is selected.
Good luck.
Posted on Dec 22, 2007
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
Boot Dell Dimension computer Safe Mode
Immediately, start pressing the F8 key once a second until the Advanced Boot Menu appears. If the computer starts up into Windows, turn the computer off and try again. Press the Up Arrow or Down Arrow key to highlight Safe Mode with Networking, then press Enter
Jan 17, 2014 | Dell Dimension Computers & Internet
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
How to enter the safe mode with network, which key should i press, please help
Hi chankp,
Welcome to FixYa! How are you doing?
Please try to do the following to boot your pc to safe mode with networking:
  • Turn off the computer. Turn on the computer then immediately start tapping the F8 key repeatedly.
Note:
You must press F8 before the Windows logo appears on the screen. If you press F8 after the Windows logo appears, the Advanced Boot Options menu does not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
  • Use the (Down Arrow) arrow key on the keyboard, scroll down to Safe Mode with Networking then press Enter.
  • Login to your User Name.
Hope that helps. Thank you for using FixYa!
Apr 27, 2011 | Computers & Internet
No screen display after resolution change
Restart your computer press F8 key from the displayed option select safe mode. After entering in to the safe mode go to device manager in my computer property, Hardware option. In that remove the display driver and restart your PC.
Sep 30, 2010 | Computers & Internet
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
How do I put my HP computer in safe mode.
Just after post(the computer boots up) and just before you see windows booting press F8, it will bring up a blck page with different selection options to boot your pc, use the arrow keys to go to the top of the page where it says safe mode and hit enter,, the computer should now boot to windows in save mode. hope this helps.
Sep 23, 2010 | Computers & Internet
How do i reboot in safe mode
HI,
Follow this steps:
  1. Restart your computer.
  2. When the machine first starts again it will generally list some equipment that is installed in your machine, amount of memory, hard drives installed etc. At this point you should gently tap the F8 key repeatedly until you are presented with a Windows XP Advanced Options menu.
  3. Select the option for Safe Mode using the arrow keys.
  4. Then press enter on your keyboard to boot into Safe Mode.
  5. Do whatever tasks you require and when you are done reboot to boot back into normal mode.
I Hope it helped.
Jan 24, 2010 | Toshiba Satellite A300-0CF035 Notebook
How do you get your computer into safe mode
As your computer goes through booting screens keep tapping the F8 Key. This will get you into a menu that will let you select Safe Mode or Safe Mode with networking.
Apr 06, 2009 | HP Computers & Internet
Missing or corupt file
try system restore if not you will have to reinstall window's
Apr 06, 2009 | Computers & Internet
Toshiba Satellite A135 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
