Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Will start and run for a while then quits.
Ran great for 2 years.problem started about a month ago.i have changed fuel filter,gas,air filter.ran great for a while.now same old thing
  • mickey813
    mickey813 May 11, 2010
    what si it do tell me what its doing and ill try to help
    Sergeant:
    Champion:
  • 257 Answers
I am not a expert just trying to help you,, if crank and run for 10 to 15 minutes then shut off ,that sound like the magneto is getting hot (some call it a coil that makes the spark plug fire) it will crank and the same thing after a hour oor so of cooling down,,hope this help you
Posted on Oct 04, 2009
Has ran perfect for several years now it feels like it has a misfire .
it sounds like you have got water in your tank I would change the fuel filter and put 2 little bottles of gas line antfreaze in your tank
Jul 11, 2015 | 1996 Saturn SL
2002 Cavalier starts then dies. Started about 1 week ago. Let sit overwrite started fine next afternoon. Ran great for several hrs. Started dying again. Replaced fuel filter, Ran great for a day. Now it...
Had a 89 cavalier did that start then die it map sensor. Also check ground wires if the become too corroded they won't start sometimes just run weird
Jan 21, 2015 | 2002 Chevrolet Cavalier
1997 buick hard to start why?
Have the fuel; pump checked for pressure bleed down after sitting, it should hold pressure within 5 PSI of rated running pressure after shutting sown the engine for extended periods.
Sep 02, 2012 | 2002 Hyundai Santa Fe
My daughter has a 1996 cavalier 2.2l and it has a rough idle like a lug sound it runs fine and everything sounds great going down the road but just when it idles its a bit rough We changed the fuel pump in...
The fuel filter is only about 5 bucks worth of work/material. Most of the time you have to get 3/8 fuel line and clamps and a filter with male adapters and just cut out the old one. But it's still a 20 minute job. Also try some dry gas or fuel treatment. If you change it and it's still acting up I think a Vacuum leak or a weak coil is the culprit. Hope this helps.
Jul 23, 2009 | 1996 Chevrolet Cavalier
1999 Buick Regal GSX won't stay running......
It's probably the mass airflow sensor and/or oxygen sensors.
Jun 18, 2009 | 1999 Buick Regal
1997 GMC K1500 4x4 5.7 ex.cab SFI injection system
fuel pump died replaced it truck ran poorly afterwards. Had a prussuer test done pump determend pump was no good. Put in another ran good for 2 days started running poorly hard to start no power. 2nd fuel pump. So i figure another bad new fuel pump wow changed it put in a third brand new fuel pump. Still will not eve start now. I had it tuned up 2 months ago new plugs rotor, cap, etc. put in a new fuel filter made sure it is on proper checked all connections for leaks. this cannot be a fuel pump problem now. no problem with the elctrical i figure i have great spark on ignition tester. I can hear the fuel pump prime when i turn the key. but when i went and checked the fuel port i had no pressure. When it is being cranked gas sews out of the test port. Also i dont if this is comon cause i used to turn my keyand go. but when i have someone turn the key and i listen at the gas tank whn the key is shut off i hear gs spraying back into the gas tank. So i am open for opinions.
May 18, 2008 | 1993 GMC Sierra K1500
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
219 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
