Question about HP PSC 750 All-In-One InkJet Printer
My printer keeps reading cartridge jammed - HP PSC 750 All-In-One InkJet Printer
2 Suggested Answers
SOURCE: repeat cartridge jams
Not really a solution but I went through this with an HP ink jet printer last year. HP basically said there was no solution. Had to toss the printer. HP's just do not hold up in my opinion.
Posted on Jan 15, 2009
HP LaserJet Pro 400 M401DN Laser Printer keeps jamming at cartridge.
Is the paper stopping just at the cartridge or is it in the fuser. We have had a few of these fail with bad fusers. The only time we have had a cartridge issue is if the drive shaft on the right side of the cartridge falls off.
Sep 14, 2016 | HP LaserJet Pro 400 M401DN Laser Printer
Hp LaserJet Pro 400 paper jam in cartridge area
Clean all of the rubber feeders with alcohol/rubber restorer in the paper path of printer.
Sep 14, 2016 | HP Laserjet Pro 400 Mfp M425dn...
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Black replacement ink in for dell 964 but keep reading missing
Check that the Gold Contacts on the front of the cartridge is clean, also the metal contacts in the printer that read the cartridge may have been jammed out of place. Use a bright torch, pull out the black and look in the spot were the cartridge goes, you will see the contacts i am referring to. they are very flimsy and can be moved very easy!!
We have come across quite a few with this problem, most of the time it is the actual printer itself though, and replacing the printer is the best resolution.
Apr 05, 2011 | Dell Photo 964 All-In-One InkJet Printer
False paper jam reading.keeps say to clear paperjam. called HP and they said its a common problem,too expensive to fix,buya new one from us for 300 bucks
Check the following Steps for fix HP printer carriage Jam :
  • Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
  • Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
  • Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
  • Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Sep 14, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer reads out "Carriage Jam". Have done all the usual stuff.... shut down,unplugged, cleaned around connections and still reads out "carriage jam". Makes a lot of noise after opening carriage and...
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hp Cartridge issue
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
Step one: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Figure 1: Lifting the top cover
Lift the top cover.
  1. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
2 - Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  1. Lightly moisten the swab and squeeze out excess moisture.
  2. Holding the cartridge by its handle, wipe the copper contacts.
Figure 4: Wiping the contacts
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Printer Cartridge and Paper Jam
Hello there Ok try see if this may help This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 09, 2010 | HP Photosmart C4280 All-in-One InkJet...
My 5610 all in one series keeps telling me that there is a paper jam. I have checked and there is no paper jammed in the printer. It won't reset. It keeps saying paper jam. Help!
Check to make sure both ink cartridges are installed properly. I don't know why it says "paper jam" when the cartridges aren't properly installed, but it does.
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon PIXMA mp 150 printer error msg reads E3 or paper jammed
it is the problem caetyridge adjust cartridge part no 40=41,830=831 or cartridge nozel is fill extra ink clean it not software open your cartridge and clean cloth
Jul 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
HP PSC 750 All-In-One InkJet Printer Logo
24 people viewed this question
Seeker5211
Seeker5211
