Question about Apple iMac Flat Panel Fan (p/n 922-4677)
Imac is displaying in negative.i.e word documents are black with white text. Photos have cyan faces instead of red. Mac is working apart from color issues.
    Scholar:
  • 33 Answers
It sounds like you managed to turn on the Universal Access inverse image setting.  Try hitting ctrl-option-cmd-8.
For future reference, go to the Universal Access pref pane under System preferences.
I hope that helps.
Posted on Jan 28, 2008
White Lines through pictures and text
Try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update. After the update, perform the Deep Clean Printhead maintenance again.
If it doesn't help, replace the cyan cartridge.
Jun 28, 2012 | Lexmark S305 IMPACT LEXS All-In-One...
Poor color printing
It means that the printer is not spraying properly all colors.
If the bar are regular, that means that the printhead is blocking the spry at regular times intervals.
Sometimes this problems is related to the printhead.
You find out if it is a faulty printhead by removing it, leaving in in isopropyl alcohol overnight or replacing it.
If printhead is fine then it is a problem with the control board.
Sep 14, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My MacBook Pro display screen is looking very strange....like a color photo negative of what it should be. White backgrounds are black, black letters are white and so on. I heard there was a problem with...
Don't worry you have put on one of the universal access settings if you go to system preferences and then universal access under display change the setting from white on black to black on white. Hope this helps
Dec 03, 2010 | Apple MacBook Pro with 17" Display
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
My desktop looks like a negative photo
go to system preferences then universal access under Display see if display is set to white on black and change it to black on white
Nov 01, 2009 | Apple iMac G5 Desktop
Can the copy setting be defaulted to black and white document?
You can set it to B+W but it will revert to its default setting the next time you print.
Jun 30, 2009 | Lexmark X1150 All-In-One InkJet Printer
Black printing is printing in pinks and mauves.
try and print a document from word with different text colors say blue green and red then in bold check text in black. this will give you a clue to what is happening to the colors.
Feb 26, 2009 | HP Photosmart C4180 All-In-One InkJet...
Colors on Mac G4 Powerbook display are severely distorted
Hi
Goto Apple>SystemPreferences>
in the System section choose UniveralAccess>Seeing and make sure it says Black on White is selected, that Use Grayscale is unchecked and contrast is set to Normal.
If it's not that then its your display and needs a service.
All the best
Sean
PiDigital
Dec 10, 2008 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Canon IP3000, problem printing black
Try to change the default printer and check ...
Also try printing from other documents see if you facing the same problem
What version of Works you using ?
Do you have the Dic for Works ?
Apr 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Open Questions:
See all Apple iMac Flat Panel Fan (p/n 922-4677) Questions
Apple iMac Flat Panel Fan (p/n 922-4677) Logo
123 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
