Question about Dryers
10-3 w/ ground wiring diagram
I'm wiring 10-3 w/ground for my dryer i need a diagram of how to wire it to the breaker box and plug in. will a 30amp single pole breaker work? do i need to turn off the main power to the box?
    President:
  • 1,922 Answers
Your 2 hots phase wires RED and BLACK need to go to the L1 and L2 terminals,the white goes to the "N" neutral terminal and green or green w/yellow stripe is case safety ground---now at the breaker the RED/BLACK are connected under each one of two screws on the breaker the white goes to the NEUTRAL BUS BAR on the palel surface where all the white wires are already, also the green goes to the neutral bus bar,this only applies if this is the MAIN house power panel, is you wire it to a sub box panel then the neutral must be isolated from the sub panel chassis and ground can still be connected to panels case
Posted on Oct 05, 2009
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
I want to build a connection 30am breaker for dryer in my house
Honestly, thats something you would need to contact an electricain about due to permits and law requirements as far as wire soze for what distance, etc. For as long as I've been doing this line of work, going on 12-13 years, the breaker for the dryer has always been located outside near the meter with all the other 220 vac breakers.
Apr 30, 2012 | Dryers
Combo unit blows 30amp breaker when washer is started. Replaced washer moter - same problem. Unplug washer motor and timmer cycles, dryer runs.
you need to check your wiring coming to the outlet. when you have a 30 amp breaker kicking, then you have a dead short. i cant imagine needing a 30 amp breaker on 110 volt line. you would need some awful heavy wire at least #10 that is not in most houses going to a washing machine circuit. go to the hardware store and purchase a plug in circuit tester and follow the instructions and if the wiring checks out then you need to check and make sure that the tub in the washmachine has not seized up. if it has not then double check the hookup on the motor to make sure the hot wire isnt going to ground. the green wire is your ground and the white is the neutral and the black is the hot. check the motor instruction as well. good luck
Sep 07, 2011 | Washing Machines
Need wiring diagram for electric cord attachment
Wiring Option1: Wiring Option2: OLDER HOMES AND ELECTRIC DRYERS NEWER HOMES AND ELECTRIC DRYERS range%203-wire_cord_connection_250.jpg range%204-wire_cord_connection_250.jpg
NEMA 10-30R 30AMP-125/250VOLT
NEMA 14-30 30AMP-125/250VOLT
This system can be configured depending on what your wiring situation is.
For example you could be faced with the following situations:
converting an old 3-wire outlet
to a new electric dryer
converting a new 4-wire outlet
to an old electric dryer
Feb 01, 2011 | Amana ALE643RB Electric Dryer
Triing to install intermatic t103 please help. Source is 3 wire 110v want to run 3 blower 110v 9.5 amps each off the t103 timer. Don't have 220v in house just 110v. I need a very simple wiring diagram I...
T103 has 120Volt clock motor, so we can wire this timer.
T103 timer is rated for 30 amps and 2horsepower and your blowers use 28 amps.
So we're getting close to max on the timer. Hopefully blowers won't all be started at one time since motors draw maximum amperage when they start.
However, you need 30 amp breaker and orange 10 gauge wire for that much amperage >> unless only one blower is turned ON at any given time.
Always match wire size, amperage of breaker and amperage of Load or it will trip the breaker.
If you put 30 amp breaker on size 10 wire it is good. But 30 amp breaker on smaller size 14 or 12 gauge wire is fire hazard.
http://waterheatertimer.org/Color-codewire.html
Add a comment at any time, and I will respond
Look at the basics:
You have 2 cables.
One cable comes from breaker box.
Other cable goes to three 120V plugs (120V is same as 110V).
Each cable has black-wire, white-wire and bare-copper-ground-wire.
How to wire the timer.
Timer has 5 terminals: A 1 2 3 4
A) Cable from breaker box:
White wire from breaker connects to terminal A
Black-wire from breaker connects to terminal 1
B) Cable going to 3 plugs
Black wire to plugs connects to terminal 2
White wire to plugs connects to terminal A
Ground wires connect to green ground screw.
Terminals 3 and 4 are not used in this case.
Here is a wiring diagram that shows 120Volt from breaker box and 120Volt going to Load
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Nov 27, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
Correct wire gauge and circuit breaker to use?
If it is only the oven that is electric and not the entire stove, the required wire size is 10/3 with ground and a 30AMP circuit breaker. If it is the entire stove then you need 50AMP range cable and a 50AMP breaker. If your doing your microwave also, you need a 20AMP breaker and the wire you need is 12/2 with ground.. If the current breaker you were running was 30AMP I would keep that for your oven and run new wire for your microwave.
Feb 23, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
240v circuit wiring to run my new Dayton Heater (3Vu34A)
On the 40 amp breaker, you should be using 8-3 w/ground. 10-3 w/ground will work on the 30 amp breaker. 12-3 w/ground is used for 20 amp circuits. Your new heater should have the electrical requirements listed in the user/installation information.
Jan 29, 2009 | Dayton 3VU34 Heater
Trying to wire a 3 wire dryer from panel box to dryer plug
Sounds like you have a 10-2 NM wire. One black, one white, one bare copper. At panel box, black to one hot terminal of breaker or fuse holder (L1). White to other breaker terminal or other fuse holder (L2). Bare copper to the grounded neutral buss bar.
At the dryer the bare neutral goes to the center terminal, the other two go one each on either side, it won't matter which way. Hot Neutral Hot. The neutral terminal of the dryer should have a wire or metal strap connecting it to the dryer frame if you are not using a four wire supply.
Oct 22, 2008 | Dryers
I HAD GAS DRYER AND I JUST CHANGED OVER TO ELEC AND I WAS TOLD TO USE THE NEW 4 PRONG SO I WIRED IT IN AND I DIDN`T HAVE A ONE PIECE BREAKER SO I USED TWO 15 AMP TOGETHER AND I HAVE NO HEAT IN THE DRYER....
You need a 30amp double pole breaker and be certain that the fuse box is a grounded box, so that your white neutral wire is separated from the green ground wire.
On the dryer your wiring should be as follows:
Red.....left or right terminal
Black...Left or right terminal, (or remaining end terminal)
White...Center terminal
Green: Attached to dryer frame or chassis terminal
In the fuse box:
Black to 1 breaker terminal
Red to other breaker terminal
White to neutral terminals in the box
Green to the ground terminals in the box
If you have no green or ground terminals in the box, then the green wire at the dryer should be connected to an active ground source, i.e., a copper water line or preferrably a copper ground rod.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 23, 2008 | Dryers
Dryers Logo
327 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
