Question about Canon Rebel XT / EOS 350D Digital Camera
Canon SD750 won't take photo if flash required
The camera works just fine if I switch the flash off. However, if I put it on auto flash, the lightning flash symbol keeps flashing when the shutter is pressed. Normally, this icon flashes when the flash is warming up.
  • 188 Answers
SOURCE: Canon PowerShot SD550
yes, the flash of your camera is not charging. needs repair.
Posted on Nov 06, 2006
SOURCE: Canon SD 550 does not work when flash setting is ON
I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
Posted on Mar 27, 2008
Agent Allan
  • 480 Answers
SOURCE: Flash Problem
Hey tombston,
An error code of 99 is Canons general error code for this camera, and they suggest cleaning the lens contacts and/or removing the battery and then reinserting it. If this doesn’t work I would try resetting the camera to the default factory settings, and directions on how to do this are on page 35 of your camera manual. If this doesn't work I would have the camera looked at by an authorized service technician. I have included a link to a PDF download of the camera manual in case you need it. I hope this helps!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=11154#DownloadDetailAct
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 24, 2008
SOURCE: A550 powershot flash not working
we all need new flashes it costs 90 bucks to replace it
Posted on Dec 01, 2008
  • 155 Answers
SOURCE: Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Posted on Apr 09, 2009
How do you turn the flash off?
Press the flash button (right on the multiselector, marked with a lightning bolt) repeatedly to cycle through the various flash modes. To turn off the flash, select the lightning bolt in a circle with a slash through it. Don't forget to turn it back on later if you want it to flash.
Jul 22, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I want the camera to flash when there is a light background, but not enough light on the subject. can i force a flash? Jim
Yes.
Press the flash button (the lightning bolt symbol on the up-arrow) to cycle through the settings. It's probably on Auto (lightning bolt with the letter "A"). Switch to On (lightning bolt).
Don't forget to switch back when you're done, or you'll always get the flash.
Jun 17, 2010 | Canon PowerShot A630 Digital Camera
How to turn off flash
Press cursor-right (marked with a lightning bolt), then select the lightning bolt in a circle with a slash through it.
May 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I turn my flash off?
Press cursor-right (marked with a lightning bolt) to bring up the flash menu, then select the lightning-bolt-in-a-circle-with-a-slash-through-it icon.
Dec 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
How do I turn off the flash on my Cannon Power Shot SD 750?
Oct 16, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
HOw to off Flash on Canon powershot SD750
turn the camera to "P"...not on auto. then push the control button with the lightning bolt... the screen should show a circle with a cross out on it on top of the lightning bolt ...that will set the flash to off... won't work in auto mode..
let me know how you do...
KEN
May 10, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon power shot SD750 can't take pic with flash
Hi
Your flash is defective, or the mainboard is defective and cannot control the flash. The only way to figure out which is the problem is to start by replacing the flash and see if it works.
You can probably find a parts camera online and use it to fix yours, if not let us know and we can help. We are an affordable digital camera repair business.
Thomas
Owner- Darntoothysam com
Apr 06, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Cannot get flash to fire in Macro mode
The manual says the flash range is 1' to 1.6 feet with setting the ISO speed to auto.
Feb 11, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Switch off flash
You can't turn it off in auto. But in any mode other than auto, press the button with the lightning bolt on the back of your camera until you the lightning bolt symbol with a slash through it on your screen.
The user manual for your camera can be downloaded free from Canon's website here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=320&modelid=12914
Aug 29, 2008 | Canon PowerShot A530 Digital Camera
DSC-S650 - Does not take a photo when auto flash is on...
Try looking in another direction, you half-way press the button wait let go then press it and it should light up with a green dot then take the picture.
Feb 24, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
