Question about Garden
5.5 honda lawn mower, will start, runs for a minute and quits, wont start back until sets for a little while????
  • 148 Answers
Test for spark after shut-down. Ignition coil may be failing under heat.
Hope this helps.
Posted on Oct 04, 2009
Why does motor quit running after 5 to 10 minutes
Check that the vent in the fuel cap is not plugged. Can create a vacuum preventing fuel getting to carburetor,
If not sure leave cap a little loose and see if stall repeats>
Mar 11, 2016 | Ariens Garden
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Craftsman lawn mower 6.5
check for water in gas if no water sounds like you got a bad carb rebiuld it again or take it back ask for another one that yours is bad
Aug 28, 2014 | Garden
Honda mower wont start
where do you spray the starter fluid in the carb or the spark plug hole?
Jul 17, 2014 | Honda Garden
We have a John deere 314 lawn mower. After you mow a few minutes there is a loud pop and the mower stops running. After it sets just a few minutes it will start right back and mow a few more minutes and...
Julie this sounds silly but try and run it with the exhaust and muffler removed. If it ticks over and then stops when it's engaged for a few minutes it sounds like its suffocating.
Sep 07, 2013 | Garden
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
Mower only runs two min and quits
Sounds like a blocked or dirty fuel inlet.
Remove the carb bowl and work the float up and down until gas flow improves. Be gentle! Just a little light pressure from beneath and the float should swing up about a quarter inch.
The short run is due to the carb bowl not refilling fast enough to keep up with full throttle demand.
Make sure when you put the carb bowl back on there arent any fuel leaks before trying to run the mower.
Good luck and be careful!
Jul 25, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Husqvarna R53SV Petrol Mower wont start. I think too much oil had been put in. I drained some out bu still wont start. Is the engine flooded? how could i start it? Thanks
Use starting fluid when it does finally start continue starting until all the oil is cleared out of the carburator you may need to repeatedly choke out the carb with the engine running to clear out the carb, do this by removing the air cleaner, start the mower on high speed rpm, and cover the air intake with your hand repeating this start/ choke/ stall procedure until it is cleared out it works, I just did this to a mower last week that had too much oil in it, the mower smoked quite a bit but eventually returned to normal
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
Weedeater lawn mower shuts off, but still has 3/4 tank of gas
On some mowers...if the gas cap vent is not working properly, it will run fine for about 15 or 20 minutes, start spitting and sputtering, if you loosen the cap, and let air back into the tank it starts running normally again.
Apr 05, 2009 | Garden
Garden Logo
157 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
