Question about Olympus Camedia Stylus 300 Digital Camera
Need to turn flash off - Olympus Camedia Stylus 300 Digital Camera
My flash don't work at all when i turn it on a
1.if you can open and reset the connection of your strobe unit of flash unit inside.
2.the strobe unit or the capacitor of your flash need to replace.
3.need to rbing to service center
Jun 03, 2010 | Olympus FE-46 Digital Camera
Flash off, no flash
I had exactly the same problem, very annoying.
The camera does not need a new tube, transformer or flash board, it only thinks that you are in the wrong mode and won't let you turn on the flash. Do the following to avoid the problem:
1. Touch "menu" then under the "rec mode" change from Burst to NORMAL.
2. Touch the flash icon and now it will be possible to turn the flash on...
May 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
Flash on camera not working lg viewty
hi, even i have the same problem, probably i don't think the flash doesn't work, but even i didn't know how to use it. however, the instruction manual says there are 3 options in flash, they are auto- that is it turns flash automatically on when it turns on. red eye reduction that is it says it will flash twice to reduce red eye but i never see the flash on and the flash off, that is it will not turn on and usually whenever you exit the camera the flash will default to turn off mode. you will need to switch the flash back. hope you understand.
Jan 20, 2010 | LG KU990 Viewty
Radio won't turn on - EQ lights flash
My Sebring radio won't turn on - it has power. The EQ lights flash - almost like a security code needs to be entered.
Apr 09, 2009 | 2001 Chrysler Sebring
My trany doesnt chge gears 1990 acura ledgend atm
I just ran into the same problem. Today my mechanic showed me 2 computers, one under the rug under the glove box on the floor. Lift rug and turn key on, not to turn car on but to just turn radio on, and see if a red light flashes on this computer. It should flash once when you turn the key on. If it flsahes more than that one time, count the number of times it flashes and then light will stop flashing and start flashing again. Count it thru a few of those times to make sure you have the number of times it flashes right. If it flashes more than once, this is called a code. Having a code means there is something wrong with car, your mechanic should be able to tell you what the code means. Mine was flashing 2X, so the code was 2. My mechanic pulled the corresponding fuse for this code, and held the fuse out for 10 seconds, and then put it back in, this reset the computer to no codes. He told me to drivew it home and then shut car off and then turn key on again and see again if any code was flashing. When I got home, no code was flashing on this computer. Good news, resetting it by pulling the fuse fixed whatever that computer was doing.
Secondly, he checked another computer under my pass. seat, to do this you need to turn key on, (do not start car), and you have to view this from the BACK seat, it should flash a red light once and then no flashing. Well, mine flashed 15X, so was a code 15. He pulled the corresponding fuse, held it out for 10 sec. and put fuse back in. It then showed no flashing except for the one time it is supposed to flash when you turn key on. He told me to check it once home, I did, and the 15 flashes (code 15) is back and what this means is I need a speed control sensor. And he said it definitely does whack out the tranny. So all I need is a speed control sensor, not a transmission replacement! Try this and see if yours gives you codes and if so, have mechanic pull the correct fuses and hold them out for 10 seconds and then put back in. Then drive your car for awhile, and recheck the computer modules again for any flashing lights (codes.) You may just need a speed control sensor!!
Oct 08, 2008 | 1990 Acura Legend
Tv won't turn on, keeps flashing red, will not turn a solid color
Sounds like the lamp needs to be replaced.
Before any repair or replacement, unplug the tv from the electricity for an hour, plug it in. This forces a system reset on the tv and may solve the problem. More likely you need a new lamp.
Aug 17, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Flash icon
Same problem with the red flash icon. I can take a picture if I turn off the flash as well, but have to turn off the flash every time I open the lens. Have had the camera for 5 years and haven't had a problem. We needed to replace the lens cover recently and after we replaced the cover we started having this flash problem. It was working fine before the cover came off which leads me to believe we've changed our settings somehow....pleas
Dec 26, 2007 | Olympus Camedia Stylus 300 Digital Camera
Open Questions:
Olympus Camedia Stylus 300 Digital Camera Logo
19 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
