Question about U-Line Icemaker
No water to ice maker
I have an older U Line ice maker model bg98! Water is not being sent to the ice maker! I replaced the valve where the water enters the unit and is being sent to the ice maker. Any other suggestions?
Thank you
  • Sassy6 May 11, 2010
    you may have a faulty water inlet valve. did you get the exact replacement?
  • 286 Answers
It will only call for water when the thermostat is satisfied. Now if you advance the icemaker when the ejector blade reaches 10 oclock thats when it should call for water. If you dont here the valve humming then it would be in the water switch inside the icemaker.Also make sure the thermostat is not set too cold. if its too cold it will never satisfy your control.
Manually advance : remove the cover on icemaker then turn the small gear counter clockwise
Posted on Oct 08, 2009
Water flow tube on ice maker leaking by causing ice blockage
When the ice maker calls for water, the valve sends water to the ice maker in the appropriate amount and then shuts off, sending no more water until the ice maker calls for it again. If the water fill line is freezing up, this will cause a leak the next time the ice maker calls for water. The water has to go somewhere. The problem is more than likely the the water valve. It is not shutting off completely and it is allowing a small trickle of water to be constantly sent to the ice maker. This causes the fill line to freeze up and clog. Replace the water valve and defrost the water fill line and solve the problem.
Apr 06, 2014 | GE Refrigerators
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water plug to the ice maker keeps popping out
Hi and welcome to FixYa. I am Kelly This is usually caused by water leaking past the ice maker water valve. That water freezes up in the through the chassis water tube and then causes either the line to pop off or the tube to pop out. The remedy is to replace the ice maker water valve in the bottom rear of the unit. I just had to do the same thing for my own ice maker. The water line kept popping off and the ice maker had been making odd sized ice cubes. After replacing the water valve everything is normal.
If you need assistance locating a replacement water valve just respond with a make and model number of your unit and I will help you find a parts source.
Thanks for choosing FixYa.
Kelly
Sep 17, 2010 | Refrigerators
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 02, 2010 | Refrigerators
On Whirlpool model WD25DIXHW02 ice maker not getting water but the water dispenser is working
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
ICE MAKER DRIP
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 21, 2010 | Refrigerators
No water to ice maker but there is to the water dispenser in the door. Whirlpool model ED22PQ
This could be two reasons. The water control valve that sends water to the ice maker or the ice maker is not sending the signal to the water control valve to send water to ice maker There are 2 valves on back of your refrigerator one for ice and the other is for the dispenser. If ice maker is empty then the signal should be sent to back control valve and 120 volts should open the valve for about 4 seconds. If that valve is bad nothing will happen.You can test the ice maker by filling with tap water and if it cycles until time to refill and no water fills the tray then I think the water control valves need replaced. Click on link below and enter your model number in model search feature. Let me know what you find, Sea Breeze
http://servicepartstec.blogspot.com/
Water Valve - Dual Outlet
P/N: 2188542
May 25, 2009 | Whirlpool Refrigerators
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice maker not making ice refrig.model#gsc23kswc ss
Check the following suggestions from repairclinic:
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Oct 10, 2008 | GE Refrigerators
No water is going onto the ice maker (Maytag Model # MZD2766gew)
the water solenoid valve is normally triggered by the ice maker itself. as it turn to harvest the ice, it should trigger the water solenoid valve to start another cycle of ice making. its either a wire harness problem that's why power is not getting to the valve or the triggering switch of the ice maker not sending power to the solenoid. i hope i was able to help you guys...
Jan 11, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Jan 05, 2008 | Maytag MZD2766GES Side by Side...
U-Line Icemaker Logo
127 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
