Question about Braun Tassimo Coffee Maker
My tassimo brewer is by Bosch and it has a filter with it, will I still need to descale also?
  • 35 Answers
No.
The water filter should be replaced every 6 weeks or so. Your Bosch machine will have a water filter indicator on the lid of the water tank which you "reset" when you change the filter.
You need to purchase a Maxtra cartridge which are readily available at many supermarkets.
* DO NOT ADD DESCALER TO THE WATER TANK WITHOUT REMOVING THE FILTER FIRST OTHERWISE YOUR FILTER WILL BE RUINED *
Posted on Mar 25, 2010
  • 464 Answers
Definately, follow the mfg suggested cleaning in you booklet. the filter will not filter out hard water particles.
Posted on Oct 04, 2009
The lid won't open to get the used coffee pod out. It seems to be stuck.
Customer questions and answers for Bosch TASSIMO T10
answers.tassimodirect.com/answers/.../bosch-tassimo.../questions.htm?...
The TASSIMO T10 Single Cup Brewing System by Bosch brings the artistry ... the machine made some funny noises and now I cant open the lid to remove pod. ... When I went to remove the T-disc, the tassimo won't open so I cannot get it out.Missing: tas5542gb
Bosch Tassimo TAS4511UC Coffee Maker Open ... - Fixya
www.fixya.com > ... > Bosch Tassimo TAS4511UC Coffee Maker
Question about Bosch TASSIMO Coffee Makers & Espresso Machines ... colors, openthe lid, put disc with the cream in the machine and the green light won't come on, only the . ... Bosch Tassimo Tas5542gb Multi Hot Drinks Machine, Black.
Why has my Tassimo brewer stopped working?
www.coffeedetective.com/why-has-my-tassimo-brewer-stopped-working...
QUESTION: I have a problem with my Bosch Tassimo brewer. ... Now when I close the machine, I open it and remove that litte tin foil circle. ... Opened my new Tassimobrewer and won't brew and water dispenser leaking all over... an ... I have a problem with my tassimo coffee maker the lid wont lift up seems stuck any ideas ...Missing: tas5542gb
Jan 19, 2016 | Bosch Tassimo Tas5542gb Multi Hot Drinks...
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Sep 09, 2014 | Bosch Tassimo T20 Single Serve Brewer,...
The 7d(fill tank light) & 7e(descale light) are flashing simultaneously, what to do?
According to the manual, when both lights 7d and 7e are on at the same time, you need to contact Tassimo.
Sep 30, 2012 | Bosch Tassimo TAS1000UC 1-Cup Coffee Maker
How much bicarb of soda do i use to descale my bosch tassimo
Sodium bicarbonate is not a descaling product. It makes a nice minimally abrasive cleaning agent when mixed as a paste. Sodium ions will exchange with calcium in a water softener when the calcium is dissolved in water. Once the calcium salt (calcium carbonate) forms, it doesn't go back into solution in a neutral or basic environment. A bicarbonate solution will be basic.
Descaling requires an acid. The Tassimo products say "Do not use vinegar" (acetic acid). I suspect they use citric acid in their descaling product. You can try the lemon-flavored Kool-aid (the version packaged in the envelopes that needs a sweetener added when it's a drink). Mix 1 tablespoon of the powder in 1 pint of water. However, you'll need to make more than a pint of the solution since you need 500 ml of liquid per cleaning cycle. (1 pint is ~473 ml.)
I hope this helps.
Apr 24, 2012 | Bosch Tassimo TAS4011GB Coffee Maker
The red light is staying on, what do i need to do?
The light stays on if you do not follow the instructions when descaling. You must hold the button for 3 seconds to descale. It takes about 20 minutes. If you press the button for less than 3 seconds with the service disc you just run the water through quickly to rinse/clean and the machine doesn't reset the rescale light.
Feb 15, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
What product do you use to descale the tassimo machine?
The descale solutions of diferent brand can do the same for all model of machines.
You can find some very good at www.partsguru.com
Jan 19, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
Tassimo red light stays on ran descaling disc twice
After many months, I solved the problem of the red light staying on the Tassimo Coffee Maker. Use these easy steps.
1. Fill a 2 cup measuring cup with hot water.
2. Mix in descaler.
3. Pour in the empty water tank.
4. Put the yellow cleaning disk in the chamber and close chamber. Put the two cup measuring cup under the spout.
5. Push and hold the brew button for about 3 seconds (until the red and green light flash.
6. Now don't touch the machine. It will do it's thing for about 20 minutes. (Don't be impatient and start to push buttons, just leave it)
7. When it finishes it's cycle. The red light will turn off. Then clean the water tank and put fresh water and run clean water through the brewing cycle 4 times. Your machine is now ready for use.
Sep 23, 2010 | Bosch Tassimo TAS4511UC Coffee Maker
Braun Tassimo Coffee Maker Logo
965 people viewed this question
Top Braun Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
