Question about Festina 16177 3 Watch
Is there any way to adjust the band without a special tool?
  • 34 Answers
Use a sturdy pin or thumbtack to push out the pin from the little hole on the link.
Make sure to examine the watch and which links have pins. Some watches are designed to have a row of removable links with pins.
Remove one end of the band from the actual watch itself. Then remove links as you see necessary.
You may need to use something a little stout like a butterknife to tap the pins out from the links.
The pin on the watch itself has spring loaded tips, push them in and it should release the watch from the band.
Posted on Oct 05, 2009
2 Suggested Answers
SOURCE: how to remove link from band
The segments of your bracelet are held together with friction pins which have to be removed first in order to adjust it. This is a relatively complicated task requiring experience and a special tool to remove and return the pins and bushings back correctly without compromising the bracelet strength.
I recommend taking your watch to an Omega authorised dealer for adjustment while you wait.
Posted on Dec 05, 2008
Adjust the bracelet
There are tiny pins either side of the wrist band next to the clasp. Remove these pins and you can take out up to two links (and a half link on some models.)
A jeweller could do it, needs a special tool to tap them out and put them back
Nov 03, 2013 | Rolex Oyster Perpetual Submariner Date...
Shorten wrist band on a RADO CERAMICA JUBILE mens watch
mcdevito75 here, Rado a great watch and with a $50.00 band, at least. BEST BET, look for a small watch repair shop in your area for this band adjustment. Links are held in by special pins and a link remover tool is need to remove these links.
Feb 11, 2011 | Watches
Omega watchband adjustment (Metal) pins or screws?
mcdevito75 here, That would depend on the band itself, I would figure most are pins, your best bet though is to look for a small watch repair shop in your area for this adjustment, special tool needed.
Aug 11, 2010 | Omega Watches
Luminox watch band adjustment
Those type of bands take a special push pin to push out the pins and can be rather tricky. My best advice would be to take to a local jeweler/watch repair as they have the best tools to do it and it normally is less the $15 to do and worth it.
Hope this helps.
Aug 10, 2010 | Navy Seal Luminox Watch
How to remove links from times watch band model #tx1282
mcdevito75 here, You"d need a special tool available on ebay called a link remover tool. But for fastest remedy and just about the same cost as buying and shipping the special tool, unless your going to do a few watches, your best bet is to look for a small watch repair shop in your area to remove these links, hold onto them just in case you need them later.
Jul 31, 2010 | Timex Casual Expansion Band 20061 Wrist...
The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Jul 21, 2010 | Seiko SGF204 Wrist Watch
I bought a webner swiss military standard issue watch with a braclet deployment band. My wrist is tiny....how do I adjust the size?
Take the watch to a watch shop and ask them to shorten it for you. (doing it yourself can be difficult as special tools i.e very thin probes, may be required.
Jan 20, 2010 | Watches
Replacing watch band on pathfinder pas410. can't get pins out to replace band.
Watchmakers use special tool to release spring bars, but it is possible to release them in home conditions. Place your watch on flat surface face down. Using pocket knife insert the blade between band and the watch lug where the spring bar (pin) end is and using lever action push spring bar end inwards. This should release the band from the watch. If all this does not work, then your watch band is attached with friction fitted pins and you will need watchmakers help, as without special pin removing tool it is not possible to remove friction fitted pins.
Rate me, plz.
Jan 08, 2010 | Casio Pathfinder PAS410B5V Wrist Watch
How to remove link from band
Nov 09, 2008 | Omega Seamaster 2541.80 Wrist Watch
Watch strap adjust
Not all watch bands are adjustable. If yours is, you will see the links are connected with tiny pins. Any store that sells watches will have the tool to remove links. Some watches require a special tool, those need to be adjusted at a store that sells that brand.
Nov 06, 2008 | Watches
Festina 16177 3 Watch Logo
746 people viewed this question
Top Festina Watches Experts
240cpa
Jimmy Accardi
Are you a Festina Watch Expert? Answer questions, earn points and help others
