Question about Drills
Remove boards fixed with ring nails
I have chipboard flooring nailed onto floor joists with annular (ring) nails which can't be pulled. I was hoping to cut around the nails using something like a plug cutter so that I can then ''jemmy'' the boards with minimum damage and angle grind off the exposed nails.
  • 44 Answers
You need to punch these nails through... unless there are thousands surely this is better than a plug cutter? i'd get a nice cheap phillips screwdriver and bust off the resin handle to make a decent large blunt punch.
Posted on Oct 23, 2009
Testimonial: "I had not thought of punching the nail though the 19mm chipboard. I guess that this would be difficult if the nail head were still intact. I'll give i"
How do I remove a jammed nail in the SHF50?
Hi Al:
Usually nailers are built so that removing jammed nails is an anticipated activity.
WORK SAFE!!!
make sure the air supply is disconnected from the nailer.
Press the safety against a piece of wood and pull the trigger. Nothing should happen but it's just one of my safety phobias.
Now you can have a really close look at the nailer mechanism.
Remove any nails that are still in the magazine.
Some nail guns have a cam or tab that will release the face of the nailing assembly.
Others have a plate secured with cap screws or little bolts. There is often an allen wrench provided with the gun just for the purpose of taking the plate off so that you can remove the jammed nails.
If all else fails, you could check with the place you rented or bought it from.
Patience, curiosity, and safety. Keeping tools working is an adventure!
May 14, 2015 | Senco Shf50 Pneumatic Hardwood Flooring...
Coilated framing nailer will drive 2 1/2 nails but gun jumps and only sets nail about 1/2 way in with 3 1/4 nails with full airline pressure.
Hi Paul,
The reason is that you are allowing the nail to "push" you off the wood when the tool fires. Probably you're using a very hard wood with a ring shank (Annular) nail. The best way of overcoming this is to push just a little bit harder down onto the tool before firing.
We see this quite often when people are just starting out with these tools, don't worry though, it gets better with practice!
Dec 31, 2014 | Air Tools & Compressors
How to build a dirt floor 20 by 20 shed
Put posts in ground.
Middle posts taller so roof will have slope
Nail 2x4s across from post to post to hold siding.
One row of 2x4s around bottom, 2 rows 2x4s around middle,
1 row 2x6s or 2x8 around top.
2x6s 2x8 will hold rafters
Nail 4x8 sheets treated plywood onto the 2x4s to make walls.
Install joists across top of structure from one wall to the other wall
Install rafters at correct angle to match slope of roof, be careful to each rafter exactly the same.
Rafters sit on outside wall
http://waterheatertimer.org/images/Pole-barn.jpg
Gene
Sep 01, 2014 | Hardware & Accessories
Creaking floors in apartment + fireboard under carpet
Hopefully by fire board" you actually mean 'floor board or sub-floor. Throughout the last century (and even prior to it), most sub floors where usually installed with nails and as a consequence, over time the nails are pried up with wear, creating the creaking sound you hear. today. In light of these issues sub-floors today are most often screwed down into the floor rafters with 2" to 3" screws. This is a difficult issue to resolve without redoing the floor or getting access through some of the spaces where the planks meet in order for you to make an insertion with a screw to make the improvement.
Jan 01, 2013 | Cars & Trucks
What is the strength of a joist hangar for a 2by 8? It has six nails straight in the face board and four through the joist at an angle.
If the hanger has an LUS it's 18 gauge. If it has LU it's 20 ga. for light loads,ceiling joists.For floor joists you should use HU 14 Ga.,or HUS 16 Ga. These # come out of Simpson strong -tie book. -
Aug 07, 2011 | Garden
I have ceramic (terra cotta) block walls in my basement (house was built around 1920. The blocks are ridgid and were not laid very evenly, although the walls are sound. Plastering is an option, but with...
My house is of similar age and construction. I built a nice TV room in the basement several years ago. My method was the same as the way interior walls are built in new construction. I nailed a 2x4 to the ceiling near the wall. I nailed another 2x4 (pressure treated) to the concrete floor directly below the 2x4 on the ceiling. Then I toe-nailed vertical studs in place. For the studs I used 2x3's since this allowed me to get a nice flat plane on the front surface while allowing an inch of space on the back for irregularities of the block wall. I then covered the studs with water resistant drywall. The results were excellent and have held up very well. I also use a dehumidifier, since my basement was somewhat damp. I built the dehumidifier into a cabinet so that it draws air from the space between the block wall and the 2x3 wall. I don't need to run the dehumidifier in the winter. For the interior walls separating the TV room from the rest of the basement (furnace and workshop area) I used 2x4s for the studs, but the 2x4 along the top and bottom were just like the first wall I described. And by the way, in order to nail the pressure treated 2x4 to the floor, I used a power-nailer that uses charges that look like 22 caliber gun blanks. This seems spooky, and is wicked loud (use earplugs and safety glasses!), but it is inexpensive and very effective. The nails don't have to resist pulling out, they only have to resist being slid around, since the wall stud holds the pressure treated 2x4 against the floor. Good luck!
Apr 07, 2011 | Drills
Hi I moved in to a recently renovated home one year ago. The kitchen had new ceramic tiles installed, with sanded grouted filled in the 5/8 inch joints. I sealed the grout after moving in as I was told...
I have a similar problem. My builder used dimensional lumber for the joists. I asked him if thet would be sufficiently stiff for tile floors, and he said yes. Then after the cracks started, I asked him why the cracks, but he said he didn't know why. It's not necessarily the subfloor but the combination of joists, subfloor, and concrete backer boards under the tile. If you can access the joists under the floor, perhaps you can reinforce them with additional joists or stiffeners before regrouting.
As for me, I have done neither so far. Wife has not complained, so I spend my spare time helping people on FixYa. Like you, I fear regrouting will just lead to recracking, and I no longer have access to the joists. :o(
By the way, your question was sorted as a Harley Davidson question. You weren't riding you bike in the kitchen, were you?
Sep 10, 2010 | 2003 Harley Davidson XL 883 R Sportster
Need to replace tub in old travel trailer. any help for removing old one, installing new one and supporting under floor if rotted??
First turn off water then remove the wall board ,or paneling at least 12 in above tub lip .,Remove more if you can.The more room you have the easer it is to slide the new tub into place. Now you should be able to reach the tubs drains unsrcew or cut them out When you have the drains disconnected .pull any nails or screws from around the tub. Look at the path you have to take to get the tub out ,you'll probably have to remove the toilet tubspout or maybe even the lavitory.when your path is clear put a flat bar between a stud and the inside edge of the tub pry the tub up and out. You way have to move from one stud to another.When its off the wall on the inside edge see if you can pick the back end of the tub up.This should make it easier.Remove all the bad flooring .You will need some lumber now replace the floor joist or scab onto them (you will need 3 or 4 ft of good joist on eather end to scab onto.If the edges of the new floor board dont land on a floor joist simply nail aboard onto the side of the joist it needs to meet on level with the other joist.Where the front of the tub sits cut a hole out about 10x12 in center of hole14and1/2in for standard tub and off the wall in front of the tub 12 in.This will give you room for the tub shoe(thats the part the tub basket screws into) Sit tub on flat level surface and measure from the ground up to the inside edge of tub .Nail a 2x4 on the inside wall about 4 ft long off the floor as high as the edge of the tub.Take your time and get this right if you dont you will have to pull the tub back up after you've set it in place..If you have room you can put the waste and over flow on the tub follow the instructions on the package use pipe compound on threds and plumbers putty on the basket lip.If your not going to be able glue the trap after the tub is inSet the center of drain 14 1/2 in off inside wall and 1 1/2 off front wall .put tub into place front in first drop down the back and slide tub ont the board you nailed up earlier level it up dont add pitch the tub has pitch built into it takes screws or roofing nail securing tub to studs hook up the drain P.S.dont nail or screw through the tub instead nail or screw just above the top liof the lip fill the tub completly up .plug up the over flow When water gets to edge of tub lip look fore leaks then release stopper and finish looking for leaks . YOU HAVE A LOT TO DO! Good Luck!!
Dec 02, 2009 | Home
I am using a Bostitch MFN200 Manual Flooring Nailer and we are having some trouble with it. The cleats go almost all the way into the floor board but are still sticking up about an inch out of the board....
2 things come to mind. I've installed Wood Floors for the last 5 years.
Make sure you have enough Air pressure running to the stapler,
and Second, Whack the hell out of it. You can be rough with it. Their designed to take a beating
When u hit it with the mallet, youre opening a valve which shoots the piston and drives the staple into the boards. hit it not hard enough, not enough air is being sent to the piston to drive it fully.
Aug 02, 2009 | Stanley Bostitch Industrial Manual...
The nails aren't going in far enough using a air cleat nailer
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Nov 23, 2008 | Porter Cable 2" Flooring Cleat Nailer...
Drills Logo
85 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
