Question about Uniden Cordless Phone
How to refuse call and have answering machine pickup
  • 8,404 Answers
Dont answer.
your machine should have a setting that will allow you to set the number of rings before the answering machine picks up the phone. Default is often set at 3 or 5 rings.
look throughout your menu system for the setting.
Posted on Oct 04, 2009
SOURCE:
It flashing f05
Error F05 on some Hotpoint washing machines means the pressure switch has "jammed" on, so the machine thinks it's full of water and refuses to spin.
http://howtomendit.com/answers.php?id=53666
Aug 04, 2015 | Washing Machines
Why won't the answering machine, when set to 'answer on' not record a message?.It goes to voice mail. Is my machine defective?
Maybe the answering machine is set to pick up at say"5 rings" and the voice mail is set to pickup at "4 rings" . Change the voicemail setting to a higher setting than the answering machine. That may be the problem.
Aug 26, 2014 | Lands Phones
My Aiwa XR has stopped playing DVD's new or copys ?
Buy a DVD cleaning kit and follow instructions, if this fails! the laser pickup assembly will need to be replaced, however the cost to repair will probably rival a new machine.
Apr 05, 2012 | Aiwa Audio Players & Recorders
I want to shut off answering machine
Use the Reception Mode button to set appropriate answering mode - press it repeatedly until a small arrow on the display will point to the desired option:
"TAD" - is the one you are using now, when the answering machine picks up the calls.
"TEL" - is the setting when no automatic pickup occurs, you always have to pick up the call and either talk (if there's a person on the other side), or press START to receive a fax (when you hear the fax beeps on the other side).
"FAX" - is the setting when after four rings the fax will pick the call up automatically (no answering machine). If you pick up the call manually after 1-2-3 rings (before the automatic pickup) you can either talk or START fax reception.
It's good to check from time to time if the reception mode is as you want it, it's easy to change it by mistake.
Good luck and come back with a testimonial if helped :)
Jan 31, 2010 | Sharp UX 460 Plain Paper Thermal transfer...
ANSWERING MACHINE
Which of the two devices should be the FIRST to answer, when you don't pickup a call -- the one with the fewest rings will be the first to answer.
Dec 29, 2009 | HP OfficeJet J4580 All-In-One Laser...
Hi, paper jam refuses to come off, any help?
There is probably some foreign object (like torn paper) caught on a switch, the ones that tell the machine that paper is going through an area and exited. There should be one after the paper pickup, and one past the fuser.
Jul 13, 2009 | Lexmark E232 Laser Printer
Fax feature
You have to set the printer to pickup 2 rings higher than your answering machine. If the answering machine picks up on 4 the printer should pick up on 6.
I believe the menu should be Setup button - down arrow key until you see basic fax setup and press ok - down arrow key until you see rings to answer and press ok - change to 2 higher than answering machine.
Now you should receive faxes and calls!
Jan 05, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Will not answer
I cannot set the number of rings for pickup, my machine picks up after 2 rings, do you know how to set it? I don't have the manual. Thanks
May 09, 2008 | GE 29869GE2 Digital Answering Machine
Brother MFC8840D only 4 rings before fax pickup?
The TAD (TELPHONE ANSWERING DEVICE) must answer within four rings (the recommended setting is two rings). The MFC cannot hear CNG tones until the TAD has answered the call, and with four rings there are only 8 to 10 seconds of CNG tones left for the fax ?handshake?. message. do not recommend using the toll saver feature on your external answering machine if it exceeds five rings.
Sep 15, 2007 | Lexmark X8350 Print, Scan, Copy and Fax...
Uniden Cordless Phone Logo
123 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
