Question about Olympus Stylus 840 Digital Camera
Battery low Same time ago, my Olympus x-840 start to show "battery low" with batteries fully charged: I buy new batteries but this not resolv the problem, after that I buy a new charger and problem still there.
SOURCE: how to activate time and date stamp on the pictures taken with olympus x-840
Bad News! I have had the same issue and have spoken to 3 different camera shops and they say that you can't get them on the images but that if you download the images to your computer you can click on the properties and all of your info for that picture will be there. I was bummed. Some digital cameras are available with this feature of date and time stamp most are not.
Posted on Jul 12, 2008
marked
  • 6487 Answers
SOURCE: My battery charger shows (green) fully charged when it is dead
THis is really a sign of a bad battery that is always being detected fully charge but its really drian , so it will be better for you to replace that battery.....
Posted on Dec 01, 2008
SOURCE: Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Posted on Jun 23, 2009
SOURCE: Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Posted on Jan 20, 2010
  • 102366 Answers
SOURCE: My FE 340 Olympus Camera tries to turn on, but
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 19, 2010
Olympus vr 310 problems won't fully charge the battery and it is brand new 7 hours and shows only justver half charged camera works
How long have you had it charging ? New batteries can take a long time for the first charge - is this mentioned in the manual at all?
Jul 25, 2017 | Olympus Cameras
Keep saying battery empty evn whn i just charged them
Some rechargeable batteries (NiCd and older NiMh) have a (bad) memory.
If they have, the charger cannot fully charge the batteries to their original
potential capacity.
Best thing to do is to buy new rechargeable batteries and a processor
controlled charger to prevent premature malfunction of your batteries.
There are new type precharged batteries which have a very low discharge
over time. Like the Sanyo Eneloop and such!
Jul 15, 2011 | Olympus FE-310 Digital Camera
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
When it is fully charge and i unplug it showing 80% but with in 30 minute it shows battery low.
All batteries have a certain lifetime to them. After so many charges the battery will eventually stop holding a charge. When this time comes, there is nothing to do except check the warranty on the battery and get it replaced or buy a new battery.
Mar 23, 2011 | Computers & Internet
Olympus C-765 - won't take photos anymore. Memory card is fine and camera has worked perfectly for the past two years. Does anybody have a solution? The camera seems to function as normal, but when I press...
Reset the menus to default or factory settings.
Then test the camera again.
Make sure that the battery is fully charged or new.
You might consider to buy a new battery (Ebay is a good place) for this camera. Then test.
Problems like this can show up when the battery is weak or not fully charged.
You may try to remove the battery for 24 hours and then after try it again.
Apr 15, 2010 | Olympus Camedia C-765 Digital Camera
Every time I insert new batterys but display shows low battery
try to reset your camera and be sure that your battery is fully charged just like a new one.
thank you for using fixya
CHARCOIS
Jan 20, 2009 | Olympus FE-170 Digital Camera
It will not turn on/ keeps saying lens error
I just bought my stylus 840 olympus digital camera in aruba one and half weeks ago. Charged the battery and it worked fine for the two times I used it. Now it won't turn on. I charged the battery. Even bought a new one and nothing happens.
Sep 07, 2008 | Cameras
False low battery warning
Same thing happened to me when I used alkaline batteries. Have you tried fully charged NiMH? If not you may have a "leak". Your next option is the service center.
Jun 27, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Olympus x-840 digital camera. Hi, there is a problem with the battery life; fully charged batteries seem to be exhausted after only a dozen or so pictures. The battery indicator plunging from a full set...
The best solution is to buy NiMh batteries 2300 mA or greater 2500 mA to 2700 mA and so I have no more problems with this excellent Olympus x 840 camera. In Belgium i have payed a little more than 50 euro for the batteries and the charger.
Lionel From Belgium
Apr 14, 2008 | Cameras
Olympus Stylus 840 Digital Camera Logo
35 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
