Question about HP Photosmart C6100 All-In-One Printer
My C6100 rings every time my house phone rings, I want to turn down the ring volume. It is plugged directly into the phone wall jack. Ideas?
5 Suggested Answers
  • 49 Answers
SOURCE: fax not transmitting or receiving
- Try to uninstall and reinstall HP driver and reconfigure your setting under fax setting - make sure of the area code is correct.
Posted on Oct 08, 2008
  • 1126 Answers
SOURCE: how do I increase ring volume on my HP Officejet
Try page 70 in this link from HP for your officejet 3680 under Control Panel.
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Posted on Oct 24, 2009
Testimonial: "thank you very much"
SOURCE: the ring volume on telephone side of J3680 is very low.
setup-basic fax setup- ring and beep volume
SOURCE: ring volume problem
the volume how to adjust because is to low , please how to adjust this is my email kenji_Jetrhow@yahoo.com please in my email the proper procedure
Posted on Dec 26, 2009
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
Phone does not ring
Make sure your mute switch is not turned on and that your volume is turned up. Also, you could plug in headphones and try to see if it rings through them. If it does, your external speaker may be bad, or your headphone jack may need cleaning. If the jack has dirt in it, the phone may operate as if there are headphones plugged in.
Nov 30, 2014 | Cell Phones
Phone ring tone in house cannot hear it do not know house to fix as instructions are in greek
must be sure handset ringer volume is NOT set TO off
2) THE Telephone line cord and power adapter are plugged in properly.
3)the handset may be too far from the telephone base. Move it close to the telephone base.
4) many extension phone on the telephone line to allow all of them to ring simultaneously.
5) if other telephones in your home are having the same problem , the problem will e in service provider
6) other electronic products such as HAM radio detect the phones cause interferences.
7)test a working phone at the wall jack.
8)remove and install the battery again and place the handset in the telephone base
9) wait for the handset to synchronize.
God bless you
Sep 27, 2012 | Lands Phones
Can not tune the ringer on
You should be able to change the ringer settings in two ways when the handset is not in use. 1) Press and hold the Volume up/Down arrows on the handset. The handset should show the current ringer setting (High, Low, Ringer Off). Press Select. The current setting should flash and you will hear the current volume (if the ringer is on). Use the up/down arrows to select your desired setting; the phone should give a ring. Then press Select to confirm. Again the phone should ring.
2) Press Prog. Use the up/down arrows to select Ringer Volume. Then press Select and use the up/down arrows to chose a new volume. Press Select to confirm.
If your phone still does not ring, there are items to check.
Try a new telephone line cord and make sure that the base is plugged into a working outlet. Move closer to the base.
Make sure that you are away from other electronics that could interfere. Check that you do not have too many devices plugged into your phone line. Each one should have an REN (ring equivalence number). The total REN for all devices should be 5 or less; disconnect the other extensions/devices and test again.
Make sure that the phone is providing a dial tone and a test phone will ring when dialed. (I like to use an old corded phone for testing.) If a test phone won't ring, you have a wiring problem. See additional trouble-shooting information below.
Remove the battery in the handset and then reconnect it. Wait for the handset to synch with the base and try again.
If you have a DSL filter, try replacing it.
The manual for the CS5121 is available from V-Tech here: http://www.vtechphones.com/vtechphones/index.cfm/product-detail/?event=ehCatalog.productDetail&ProductID=55#documents .
Phone line testing:
Using a test phone with a new line cord, check for dial tone and ring at the first jack. If your test phone rings, then the problem is the handset. Move to another jack on the line and test again. If you get a ring here, the first jack or the wiring to the jack has a problem. If there is no ring, find where your service comes in. Open the box and check the type of connection. If you have a relatively new phone service, you'll find an RJ-11 jack. Plug in your test phone and check for dial tone and ring. If it doesn't work or there is no RJ-11 jack, contact your service provider. They can test the line and will repair any outside problems for free. If the problem is inside, you will need to look at all the exposed wiring for damage. If only the one jack is bad, open it up and check that the wires are properly connected. There are two types of jacks: one secures the conductors with screws, the other is a keystone. The keystone jacks require a punch down tool to press in the conductors. This punchdown tool is available from many home improvement stores in the wiring section. This site has a picture of how the conductors should be connected: http://www.lanshack.com/wire_phone_jack.aspx .
If the handset is bad, you can try a replacement handset, if available. If the phone is under warranty, contact V-tech. Otherwise decide if it is worth servicing, these phones were not meant to be user serviced.
I hope this helps.
Oct 06, 2011 | Vtech CS5121 Cordless Phone
I cannot send faxes on my HP 700. When I call my fax number it does not ring or answer. The unit is plugged in and the screen has normal information. It does print out sending failures.
If your fax does not ring when you call the number then it is not properly connected to the phone line.
Try checking the connections on the fax and to the wall jack; make sure the phone cable is connected to the correct jack on the fax machine.
If this is all good and still no ringing, then you should try another telephone cable or try connecting the fax to another phone jack. The modems and jacks on fax machines rarely break down but if you have tried different wall jacks and different phone cables then you can finally assume that the fax machine is broken.
Thanks,
Pat
Nov 07, 2010 | Office Equipment & Supplies
I have 7 prostar 816 phones. I have programmed one of them to ring with #62, but it is still not ringing for incoming calls. How can I fix this problem?
There could be a couple of issues that would stop ringing on a set. Do not disturb could be on which is turned on/off by pressing the mute/DND button.It could also be a problem with the ringing volume control on the right side of the phone,usually adjusting the volume up and down a couple of times frees up the ringing. Lastly, it could be a defective telephone set. Try exchanging the set with a working set to see if the trouble follows the phone or stays with the jack/port.
Jul 01, 2010 | Samsung Prostar 816 Phone
Fax does not connect on distinctive ring
It's either your phone, or it's your fax machine that does not support fax through phone.
Jan 30, 2009 | HP Officejet 5610 All-In-One InkJet...
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Me again 2210xi all in one fax problem
The "tags" says no dial tone, so I wonder if you can send faxes? If not I would suspect the connection is not correct. The preferred setup would be to connect the phone line from the wall to the line input of the 2210 and then plug the phone (and answering machine) into the phone output on the 2210. Looking from the back the should plug into the jack on the right and the line to the wall should plug into the jack on the left. It is possible (??) that the 2210 will not present an autoanswer option if an active phone line is not connected. You can see the setup instructions for the Fax here. Note HP recommends using only a 2-wire phone line.
Also, do you have DSL on the same line? This can cause some issues.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jun 26, 2008 | HP PSC 2210xi All-In-One InkJet Printer
We cant hear the phone ring in our office now!
Call your phone from another phone. Don't answer it. Press you volume up/down button. Up makes the ring louder and down makes the ring softer. I bet someone turned you ring volume down. Once it is set it stays there. God Bless. Jerry
Mar 24, 2008 | NEC Dterm DTP 16D-1 Corded Phone
HP Photosmart C6100 All-In-One Printer Logo
23 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
