Question about GE Spacemaker JVM1640SJ Microwave Oven
My JVM1460WA just stopped working. No display at all. What could be the problem?
  • GE Master
  • 8,404 Answers
Check the fuse ...
Dont tough the silver can inside. Remove the cover, find the fuse on the floor. Check it for contunity.
Posted on Oct 04, 2009
GE spacemaker microwave turns off during cooking and display goes black
Step 1:
Door Switch
If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently
Step 2:
Main Control Board
If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel
If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
High Voltage Transformer
If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermostat
If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostat
Step 3:
Step 4:
Step 5:
Step 6:
use the DVOM tester and fix it. God bless you
Feb 08, 2013 | Microwave Ovens
Need exact dimensions of GE JVM1460
If this link does not work paste it into a search window and then click the link:
JVM1460WA-GE Profile™ SpacemakerXL 1.4 Cu. Ft. Microwave Oven
GO to this link: http://www.geappliances.com/service_and_support/literature
Then type in the model JVM1460SA001
15 & 3/4" high 16 & 1/2" hole required for vent connection in rear
15" deep
Needs a 30 inch wide hole for installation
Thanks for choosing FixYa,
Kelly
Aug 14, 2011 | Microwave Ovens
Microwave will not heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
l'l'l'l'l'l'l'l'l'l'l'l'
Aug 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
BAked Potato caught on fire in GE Microwave
Fuse is behind the control panel. Has cavity sensors and a magnatron thermal disc also. Start with the fuse and then pull it down if not the problem. Eric
Aug 27, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
Nov 13, 2017 | Kenmore Microwave Ovens
Display not lit up
Seems like the display panel went bad. You can check for sure by unplagging the unit for 45 seconds and plugging it back in. If still no display order a new display panel.
Please rate if you are satisfied
Feb 12, 2009 | Microwave Ovens
Nothin works on my key pad
Here are lock / unlock schemes for three recent Sanyo models:
- Press and hold Stop/Cancel for 3 seconds
- Press and hold Stop/Reset for 3 seconds or so
- Press Stop/Clear five times
Hopefully one of those will work.
If none of these work for you, contact Sanyo Service Customer Service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 10, 2008 | Sanyo EM-V5405SW 1200 Watts Microwave Oven
Buttons won't work
It sounds like has loose wires that are contacted to the display screen or the lcd lights are busted on the display I would return it.
Dec 28, 2007 | Sharp R-1500 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
145 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
