Question about Cameras
Wont take picture, Top screen says ERR. It's a D50
    Guru:
  • 441 Answers
If it's a problem in AF and M mode it is an indication that it is probably your shutter. I have heard of similiar problems. Best bet is to call Nikon and explain your problem. Might have to send it in to be repaired or replaced.
Please rate!
Cheers
Posted on Oct 04, 2009
Err on top of display on camera
Unfortunately, this probably won't be a good situation. Most of the time the ERR(or) message you're getting shows when there's an internal problem, and most likely a shutter error. Not an uncommon problem with the older consumer models like D40, D50, etc.
Dec 27, 2013 | Nikon D50 Digital Camera
Err popping up on top of bar when try to take a picture flash does not come up and also when looking in it also appears inside
When a Nikon camera says Err, something is wrong with the memory card. Perhaps it is not inserted correct. Or not a card inside at all. Perhaps you can't write to the card or it should be formatted.
When you have a Err, the camera won't do a thing, to avoid the user can think he is shooting pictures and the camera won't save one.
Nikon d50 wont take pictures and displays r10 warning
R10 is not a error code, it tells you how many pictures (on average) the camera can shoot before it has to stop and clear its internal memory by writing to the SD card.
Is there a card in the camera? It will not fire without one. Also, if you have taken 20 or 30 thousand exposures, then the electronic switch (not the button on the top) that fires the camera may be worn out.
Jun 30, 2011 | Nikon D50 Digital Camera
My Nikon D50 camera showed err message on the screen. I took shoots but it turned out to be only dark photos. thanks!
Hi,possibly your camera has aperture control mechanism damaged, if so, has to change it.
Best reggards
Feb 23, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
I have a Nikon D50 with a Err message and I can't take pictures anymore. What would be the cause for this? Eric
"err" is a cmara malfunction. If the camera has a hardware reset button, give that a try. If that does not work, then examination by an authorized Nikon Service Center is advised.
Nov 01, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Flashes Err and clicks
hi..
This screen shows areas of the photo that are overexposed slightly.
It flashes them to help you.
You get to this screen by pressing the up or down arrows when displaying the pictures you have taken.
To change it just press the up arrow when the camera is showing the screen until you get a display without flashing.
Once you have done this the display will be steady.
If you get any other screen in future you may have accidently pressed the arrow again.
Just cycle thru the displays to get back to steady.
thank u
rate me!!
Jul 27, 2009 | Nikon D50 Digital Camera
"Err" message
ERR is like saying to your doctor your sick. It covers a very wide host of problems. Only Nikon once the camera is connector to there computer can give you a better diagnosis.
Jun 30, 2009 | Nikon D50 Digital Camera
Flashing "Err" message with a code 999. Can't shoot pictures.
Try resetting the camera.
First a soft reset is to just replace the battery. If that doesn't work try a hard reset - on the bottom the other side to the battery flap.
May 06, 2009 | Nikon D50 Digital Camera with 18-55mm and...
Get ERR message when trying to take pictures/troubleshoot no help
Two possible things to check.
First, a bad memory card can easily cause this problem. Try replacing the card.
Secondly, could be a poor connection between camera and lens. Be sure contacts around the rim of lens and lens opening are clean and free of dirt, dust and debri. Do not get anything inside your camera when you remove the lens. Dust is a killer to the sensor in the camera.
Mar 22, 2009 | Nikon D50 Digital Camera
Err 999
You can reset the camera 2 ways... soft reset is to remove and replace the battery. To hard reset, there is a microswitch on the bottom of the camera body opposite from the battery compartment. Youll have to reset the camera's clock if you do this. If it still doesnt work, have a Nikon authorized camera shop look at it.
May 21, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
