Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
SAMSUNG LNT4065F KEEPS WILL NOT COME ON ANYMORE. FIRST IT WOULD'T COME FOR ABOUT 10 MINUTES ON-OFF ALL THE TIME. KNOW THE BEST THAT I CAN GET IS COLOURED VERTICAL LINES IF IT COMES ON.
  • Samsung Master
  • 3,866 Answers
Yeah your decoder is giving on you and it needs to be replaced. www.partstore.com would have the part if you want to install it yourself.. But if you hvae a tech do it you looking around $150 upwards if you want a total solution.
Please rate and Thanks
Posted on Oct 04, 2009
Samsung 3 keeps losing minutes when turned off
Put it in airplane mode before turning it off. I changed to Straight talk it has unlimited everything I don't have to worry about minutes anymore for 45.00 a month
Aug 26, 2017 | Samsung Televison & Video
Samsung lnt4065f
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Apr 06, 2016 | Samsung Televison & Video
What is the meaning of 4Eerror code in samsung SW55V3 washing machine
When the pump keeps running, you have a 'slow drain problem'. The machine knows it should empty in a certain amount of time. If it doesn't it runs the pump all the time. You can usually reset it by just unplugging it and counting to 10 before reconnecting.
It is usually caused by blockages in the filter or in the pump itself.
http://landersappliance.com/Blog/ArtMID/1641/ArticleID/43/Samsung-Washer-Service-Problem---slow-draining
and this video.
How to Diagnose Washing Machine Drain and Pump Problems
Jan 09, 2016 | Samsung Washing Machines
Snowy picture for 10 mins every time I turn on
SAMSUNG is known by the really famous CAPACITOR problems with Taiwan Capacitors that this condensers are not so good self-healing anymore in about a year of 3 or 4 and have leakage or are deformed. this can be several parts inside the chassis, when its get not the right capacity anymore but if its temperature goes up by time then there is coming up a forming of the capacity slowly back. 20 minutes aware this is the first part where you begin is the mains board of the hdtv
The use of Taiwan capacitors everywhere and too little stress tolerance 16 v where 13 v is used but its all
taken too tight , thats Samsung and many other Brands with Taiwanese capacitors token to tight about the volts .16v 10 v replace with 10 v higher models over the time the size of the capacitors are smaller than before.
replace with good German capacitors or a good Brand Japanese also in the mainsboard in the first place , and replace if there are all green colored 3 watt type resistors if they are used in the mains ACbord primary because the end-caps of this resistors if thats 3 watt type can have also sometimes problems because of shrink and distention because the heat and cold are playing parts by the Samsung resistors they are sometimes terrible of the green 3 watt type. use normal cheap Vishay resistors instead the have also no such problems for shure.
Sep 18, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
Samsung galaxy 3 is not sending my messages out
In order to reset your phone, turn it off for a few minutes, take out the battery to refresh your phone. After 10 minutes, put battery back in and try again. Check for Samsung updates from your carrier.
Aug 27, 2014 | Cell Phones
Samsumg bluray e6500 keep ejecting
Reduce any lights or reflections that can be detected by the "remote eye" on the player. Increase the distance to other electrical equipment.
Mar 30, 2014 | Samsung BD-E6500 3D BluRay Player No...
Having a problem with my 2 yr old Samsung LCD TV [LNT4065F], which I understand from several unfortunate owners, is quite common. When trying to power up, the TV will not turn on, just keeps clicking and...
U know basic electronic's and soldering?Take ur tv aparts,Where the A/C cord plug in that ur power supply board.Searches all around the board,those capacitors are bad,they usally have bulges up on it top or puff up on it top.Replaced these leakages gases capacitors,ur power will retrun to normal.Or tries Websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.The cost about $100-150+shipping.Ha,Ha u supply the labors,and the part now,that why it cheaper.
May 03, 2010 | Samsung LN-T4065F Television
Two (2) minute start up Samsung LNT4065F
I found information on the earthinfo website that seems to pretty well describe, what I think to be the problem. I believe this to be a capasitor problem on the pwer supply. I'm going to try and replace these as time permits. It Seems MANY have had this problem and I'm convinced this is the resolve I'm going to persue. Very helpfull website, step by step instructions and pictures. I do not, at this time, believe this to be any software issue.
Sep 09, 2009 | Samsung LN-T4053H 40 in. LCD Television
My samsung lnt4065f quit working we took back off and found two capacitors are swelled, is this easy to fix it myself?
Yes it is easy to fix...the capacitors can be found at your local radio shack. Remember when replacing electrolytic capacitors, if you cannot find the exact uf and v specs, you can go higher in both uf and v specs, never go lower as you might blow the caps again. I have done several samsung lcd monitors and i replace all the electrolytic caps on the power supply board, exception being the 1 or 2 high voltage caps (200v or 400v). Make sure you keep notes as you remove the board, so that you can put it back together correctly. In my experience, it's only the caps needs replacement! Good Luck!
Aug 21, 2009 | Televison & Video
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
177 people viewed this question
Henry  Thomas
Henry Thomas
