Question about Xerox Phaser 6120N Printer
Xerox Phaser 6120 - Stuck in Starting Printer Mode
Hi. I reset my xerox phaser 6120 to factory defaults. Then the next time I turned the machine on it has been permanently stuck in "Starting Printer" mode. I have tried the red / clear button with no success.
Any other suggestions?
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
  • 2072 Answers
SOURCE: how to reset chip on toner cartridge for Xerox Phaser 6125?
Just google Xerox 6125 chip and you will find a couple of sources. The ink will need to be added also.
You can often times find them on E-bay.
Posted on Jan 28, 2010
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
  • 2072 Answers
SOURCE: How do I reset a Xerox Phaser 4500 Centreware
this should restore it to default.
By default there is no username or password required to access CentreWare Internet Services. If a username and password have been configured for CentreWare Internet Services and you do not remember the username and / or password, reset the printer to factory defaults (NVRAM reset).
To reset the NVRAM, go to the front panel's Main Menu:
  1. Select Troubleshooting, then press the OK button.
  2. Select Service Tools, then press the OK button.
  3. Select Reset NVRAM, press the OK button.
  4. Select Reset NVRAM and Reset Printer NOW, then press the OK button to reset all the settings to their factory default values.
Posted on Mar 03, 2010
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Phaser 6120 stuck at Printer Starting screen
what problem were you having that you chose to "reset" the printer ?
Tallon41
Sep 12, 2012 | Xerox Phaser 6120/YN Laser Printer
I have a nightmare called xerox phaser 8560N It continuously says "close exit door to continue printing" I have checked actuator switches and tabs, everything is present. I do not know what to...
If strange and unlogical things happen like this, it might be an electronics lockup.
Sometimes it will help to do a factory reset of do the diagnostics.
To go to diagnostics mode:
Hold down the back and help button as the Xerox logo moves towards the center.
The machine will eventually say 'Rebooting in diagnostics'.
From there you can run more testing.
(Be patient the machine takes a while to enter diagnostic mode).
Aug 12, 2011 | Xerox Phaser 8560N Laser Printer
Xerox phaser 6120 not duplex printing since it's wireless network
You have to go to printer properties and look for "optional functions" or something to that effect, and check the option "duplexing unit" or similar.
By default the computer does not know, that your printer has duplex capabilities.
Oct 27, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 3100 Printer Error Fuser Temp.
fuser Temp printer error problem.please give me the solution.
Sep 14, 2009 | Xerox Phaser 6120/YN Laser Printer
Dead Display on Xerox Phaser 6120
Did you receive any good solutions? I have a Dead Display on a Xerox Phaser 6120. Thanks!
Rick
RickHamiltonMBA@earthlink.net
Sep 11, 2009 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 6120 registration problem
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} We had purchase our Xerox Phaser 6120 printer in 2007.
Last one month is past we can’t printing our staff. We made complain regarding the same to Sunshine Service they told us that the sensor is gone, and they say its every difficult to get it, but they are trying to get it. Also we have spent on baying new toners for the same which is become useless now.
Pls. reply to mozaicdesign@gmail.com
Jul 09, 2009 | Xerox Phaser 6120/YN Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
STARTING PRINTER menu error
Have you tried turning it off, then when powering up again hold down the red clear button until you hear the printer start it's warm up cycle. I hope this helps!
Apr 16, 2009 | Xerox Phaser 6120N Printer
Password Problem Phaser 6120
Unfortunetly, you will have to reset the printer. Using the control panel go to the default setting and scroll to reset to factory settings. Then select yes and that should take care of it. If not, then in the rear of the printer under the cover, upper left side you will find the memory button battery. Remove the battery, unplug the unit, and turn it on for about a minute. Turn it off and put it back together and you should be ok. Good luck.
Feb 19, 2009 | Xerox Phaser 6120/YN Laser Printer
Xerox Phaser 6120N Printer Logo
179 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
