Question about Gateway (4000811) Motherboard
Wires from power button to where they connect
I had my comp cleaned out and re installed but when i got home with it and hooked everything up it woukd not do nothing so i took off the side panal and i noticed that the wires from the power button was just laying there not hooked up there are like four different wires with little plugs on them what i want to know is in what order do they hook up i have them hooked up so i can now power up but my lights on the front dont work so i was wondering if anyone knew the correct way of connectint them up
thanks
  • trader5904 Dec 23, 2007
    the only thing i can see is SIS
    962Lua
    sis'02
    ppc0276
    0418fa
    its a foxcom mother board
GIVE
Posted on Nov 23, 2008
  • 31 Answers
Inside the catalogue that came with your motherboard you will find a page in the "hardware setup" section that has the connectors on your motherboard numbered and tells you which connector goes where, and if u can't find the catalogue then plz put the motherboard model number so i can find its catalogue and send it to you or tell you how to connect it.
Posted on Dec 22, 2007
I just bought a used iphone 2G or 3G not sure, updated it to ios 4 and now it says insert sim.. i did, but now it says connect to itunes. when i connect to titunes it says the iphone cant connect to itunes...
Make sure you have the latest version of itunes on your comp & power up comp & itunes
-power off your phone
-hold down the home button (around 6secs) then insert USB cable while still holding button then release button when cable plugged in
-itunes will then bring up message saying that the phone has been detected in recovery mode
- it will then give you choice to restore your iphone
-continue with this choice & restore your phone as a new iphone, this will wipe everything from the phone including the passcode. I have pasted a link below if you get confused with the restore
Hope this helps!!
Click here for restore info!
Jan 12, 2011 | Apple iPhone Smartphone
Replacing Stereo in 99 Plymouth Neon
What for? All you need to do is hook up the power wire, a ground and the speaker connections and you are good to go.
Want some good stuff go to Crutchfield. Have everything and very helpful with installation Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Sep 04, 2017 | Sony Car Audio & Video
EMACHINE T6534 COMP. WANT BOOT . TRYING TO CHANGE V-CARDS
This could be a few things though if you have already checked the memory and HD. The next thing I would tell you is that you should check the cpu. Also make sure that everything in the BIOS is set to the default settings when you start it.
Feb 04, 2009 | eMachines T6534 PC Desktop
Check Speaker banner keeps coming on
If you have a ohm meter plug it into the back of the speaker it should read about 5.5 ohms
Nov 30, 2008 | RCA RT2500 System
Frozen and my comp wont recognize my dj
Hold pause down, press reset button with paperclip (in the little hole on left side), then choose clean up, then select reboot. It will reload your library and it wont erase your files try it, I did and it worked fine after that.
Sep 16, 2008 | Dell DJ MP3 Player
Installation
We can help you.Welcome to contact www.playpower.com.cn
Aug 21, 2008 | Car Audio & Video
New power supply problem
One of the reasons that this could be is that the power supply doesn't have enough power to power everything. Trying exchanging it for another one that has more watts. If this is an exact replacement as far as the wattage goes, then your problem may lie else where, and you may want to take it to a reputable local computer repair shop for further inspection.
Aug 04, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Gateway (4000811) Motherboard Logo
794 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
