Question about Microsoft Xbox 360 Console
Memory or video Issue?
Xbox 360 powers up and goes into the main screen (my xbox)
after 2-3 minutes of operation, it locks up an displays little squares throughout the entire display of the last screen it was showing. The audio also ends.
cycling power will repeat the experience.
Help!
  • 37 Answers
Try unplugging everything and letting it sit for a few minutes. 10 is a good safe number. Plug everything back in and try again. If this doesn't work, you have a serious issue that microsoft needs to address and fix.
Posted on Oct 04, 2009
  • simsk Nov 04, 2012
    Microsoft did replace the unit
When i press start on the main menu it says (Loading settings "settings" from hard drive. Please do not turn off your xbox 360 console...) and it freezes, how can i fix this?
Ok I have seen this issue many times before , first unplug the console . Disconnect the power cable , a/v cable , controllers , any usb devices , & finally disconnect your hard drive . Now let the system sit for a few minutes , then plug in just the power , a/v cable , & a controller . You should be able to boot your Xbox 360 successfully now . At this point you can either connect your hard drive while the system is running or you can turn it off & connect it . This should fix the issue , if not you can attempt to clear the system cache in the Settings Menu or worst case download the latest update from Microsoft on your Computer , then follow the instructions & place it on a freshly formatted USB Memory Stick . Then place the USB Memory Stick in the 1st USB Port on the Xbox 360 & boot the console .
Apr 15, 2011 | Microsoft Xbox 360 Console
1 red light on xbox 369
hi, here follows a possible solution from Microsoft support:
One light on the ring of light around the power button on your Xbox 360 console flashes red.
You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
c. Press the release button on the hard disk, and then lift the hard disk from the console.
d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
Jul 31, 2010 | Microsoft Xbox 360 Console
Modern warfare 2 freezes up have to push main power button to reset......any help?
Hi
Modern Warfare 2 freezing related complaints have hit the web recently, however you can follow these steps to resolve the issue
Clean your disc only if it is dirty.
Install the game on your hard drive and play it that way.
Make sure your 360 has adequate ventilation.
Let me know if this helped
Nov 18, 2009 | Video Game Consoles & Games
Memory unit not detected
make sure you have a Xbox 360 memory unit
sometimes when you update you 360 from Xbox Live, and if ure using a non 360 memory unit, youre unable to acces the dashboard.
Nov 02, 2009 | Microsoft XBOX 360 ARCADE Console
My screen goes off control pad starts to vibrate and 2 red lights flash then fan stops???but have opened it up and cleaned it?
This could be a power issue with your Xbox. You could try cooling it down and waiting a few minutes and trying again.
See if this video helps you: http://www.youtube.com/watch?v=bvBPwJKp59g
Jun 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 plays for a few minutes and then the screen goes black with no sound or picture.
your graphics processor IC chip needs its solder joints reflowing, and the heatsink re securing.
This will solve the problem.
Regards
FixMyConsole
May 19, 2009 | Microsoft Xbox 360 Console
360 lock up/Freeze
that isnt normal if it says disc is unreadable look at your discclosley and check for a ring if it freezes well theres no doubt about it your xbox is ****
Apr 16, 2009 | Microsoft Xbox 360 Console
Black Lines show up on my screen from Xbox 360 not T.V.
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. This issue is caused by the video card inside the xbox 360. If you still have warranty better send it in for repairs ( Call xbox customer support )
Good Luck
Apr 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 error 73
Sometimes the easiest way is the fastest way. The signal reset button (the little one to the left of the power button) is also the unofficial reset button for the Xbox 360. With the Xbox turn off, press this button and keep pressing it while you press the power button. Do not release the reset button until you see the system booting up normally. Of course, if there is a permanent or a more serious damage to the system, it won’t work or the error will be recurrent until it is solved. Resetting just clears the error from memory.
Dec 09, 2008 | Microsoft Xbox 360 Console
Xbox 360 sound but no picture
ARE YOU PLAYING YOUR 360 ON A REGULAR TV?
Nov 08, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
54 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
