Question about T-Mobile MDA
T mobile mda
My phone will not charge what may be the problem
  • Anonymous Mar 09, 2008
    it will simply not turn on even though i'm charging it
I had a problem with charging my MDA using a usb cable connected to a computer. And I used a different adapter to charge it and nothing worked so I used an adapter from my SDA to charge the MDA and it worked my sda adapter is hardly used so try using the adapter that comes with the phone if not try another soloution.
Posted on Mar 11, 2008
If the unit is not new have you checked the status of the battery and is it a manufacturer's battery - some units are quite sensitive to that.
The problem may also be with the charger
Posted on Dec 23, 2007
  • 16 Answers
SOURCE: help ASAP my MDA wont turn on
it might take a while tfor the light to come on . leaving it on all night should not hurt it. try charging it again
Posted on Nov 12, 2007
SOURCE: battery won t charge or operate phone Problem - T-Mobile MDA Compact Smartphone
First of all, be aware that the MDA can NOT charge unless the OS is fully loaded. If for whatever reason your battery gets fully depleted, you have to do the following (it involves ruining a 5 $ cable and doing some surgery):
- first, go out and buy a new USB-to-mini-USB cable, unless you have 2 already (or one and the original charger)
- take out the battery
- take the USB-to-mini-USB cable, cut off the mini-USB plug and expose the four wires
- strip the red (+) and black (-) wire and twist the copper ends of each wire now CAREFULLY attach the right wire to the right connector on the battery and tape it there so it stays firmly on
- put the cable in your (running) PC or put the charger in the wall socket let the battery recharge for an hour or so, then put it back in the Wizard and reboot
- now when it is fully rebooted, you need the second cable to charge your Wizard completely, the way you're used to.
Worked for me! I've kept the ruined cable, just in case it happens again.
Posted on Jan 07, 2008
SOURCE: Broken USB Port on T-Mobile MDA
http://rapidshare.com/files/73138701/Wizard_Service_Manual.rar
Use a T-6 Torx driver to remove the four screws and use a fine point soldering iron. Takes about 30 minutes to do it slow and carefully.
Posted on May 19, 2008
  • 18 Answers
SOURCE: t mobile mda pda ohone repair
Try http://www.pdasmart.com for your smartphone repair needs!
Posted on May 25, 2009
  • 195 Answers
SOURCE: T-Mobile MDA Phone wont now charge or turn on
http://support.t-mobile.com/doc/tm22933.xml?related=y&Referring%20Related%20DocID%20List%20Index=5&navtypeid=6&pagetypeid=7&prevPageIndex=1
Posted on Mar 21, 2010
Mar 06, 2010 | T-Mobile MDA
MDA acting funny
try a soft reset. start/settings/clear storage. enter 1234 when asked and the phone will guide you through the proccess. make sure you have a good charge before starting.
Feb 23, 2009 | T-Mobile MDA
T-Mobile MDA won't hold a charge
if you insurance on your phone I recommend using it, I had a MDA for a couple years and had about every problem in the book, but not that one. It sounds like you've done everything possible, the only other thing i could think of is a hard-reset. Anything beyond that would tinkering with the internal hardware.
I think you can get a MDA pretty cheap on ebay these days
Jul 19, 2008 | T-Mobile MDA
T mobile mda
mine also did it and finally nothing on even I thought battery died I bought a new one.
Jun 14, 2008 | T-Mobile MDA
My daughter's MDA had the same problem. I just opened the phone and soldered the legs on the corners back to the board. You have to bend the pins on the back of the plug down to make contact with the board, before you solder. Place plug back down and line it up with contacts. If done right should work as normal. Hope that helps
Jan 16, 2008 | T-Mobile MDA
Tmobile mda
Try charging it with the AC adapter it came with.
If that doesn't work try charging it via your computer using a USB cord
Jan 03, 2008 | T-Mobile MDA
T-mobile mda is not charging
i have the same problem.... may anyone help me.. it is not charging.. and not giving any sign of charging.. plz reply
Nov 14, 2007 | T-Mobile MDA
Help ASAP my MDA wont turn on
Nov 06, 2007 | T-Mobile MDA
T-Moblie MDA Dead
I did the same thing, Blue Bay Electronics had a seven day warranty just long enough to fool me into giving a good report. Anyway look for a repair center and spend another 100.00. Good luck
Oct 07, 2007 | T-Mobile MDA
T-Mobile MDA Logo
93 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
