Question about Acer TravelMate 2413LCi Notebook
Start up says NTLDR is missing
Start up on ACER Travelmate 2413LC1 says NTLDR is missing, have no recovery CD'S
  • Craig The Geekinator
    Craig The Geekinator May 11, 2010
    @ stephenholla. You have a very common error with typically very common fixes. What was occuring (BIOS modifications, hardware/software changes, system recovery, etc.) prior to this problem? Do you have a floppy disk drive? So you have no recovery CD's ... do you know anyone you can borrow a Window XP installation disk from (with that you can perform couple possible fixes using its "Recovery Console". "Today's the best day of my life ... and NOW you're part of it!" Geekinator
  • Acer Master
  • 1,147 Answers
Http://www.tinyempire.com/notes/ntldrismissing.htm. read here lots of info for the NTLDR
Posted on Oct 05, 2009
I cannot start my laptop,its say no bootable cd in atapi cd-rom and ntldr is missing-acer travelmate cl51
Either the boot record is corrupted or the drive is bad. You will need to reinstall the OS with your OS cd or restore your system to factory setting.
Feb 07, 2012 | Compal Custom CL51 Notebook
When we switch on the laptop we getting ntldr missing press any key to restart
The error message "NTLDR is missing" means that the Windows boot loader (NT Loader, NTLDR) cannot be found.
This often occurs when the computer tries to boot from a drive other than the one Windows is installed on, due to a change in the drive configuration or because you left a bootable disk in a removable drive. But it may also be because the NTLDR file has been corrupted or deleted
First, check the boot drives to make sure that the computer is not trying to boot from a different drive to the one that contains Windows.
  • Check that there are no CDs or DVDs in the CD/DVD drives.
  • Check that no removable drives are plugged in to the USB ports.
  • Check the boot order in the BIOS Setup to ensure that the computer boots from the drive containing Windows before any other bootable devices.
If this does not resolve the problem, you will have to repair the NT boot loader.
However, if your computer is using Windows XP and you have a Windows XP installation CD you may be able to boot from this and use the Recovery Console to fix NTLDR manually instead.
Nov 28, 2010 | Acer TravelMate 2300 Notebook
Acer aspire one zg5 - ntldr missing. Can you help and how much is the cost. Thanks
have an acer aspire one zg5 ntldr missing and computer has no cd drive and i dont have the xp cd -rom how can i install then to get my computer back working. please someone help me
Oct 20, 2010 | Acer Aspire One Netbook
The Acer travelmate 240 boots up and after the Acer screen goes to the windows didnot close properly screen and then back to the Acer screen. How to boot it up ?
First try to start in safe mode:
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Apr 03, 2010 | Acer TravelMate 240 Notebook
Ntldr is missing press clt alt del to restart
The NTLDR and Ntdetect.com files are important system files that are used by your computer to start the Windows XP operating system. These files can become damaged, corrupted or deleted for a number of reasons and are usually brought to your attention by the "NTLDR is Missing" error message.
Follow these easy steps to restore the damaged/corrupted or missing NTLDR and Ntdetect.com files from the Windows XP CD using the Recovery Console.
Time Required: Restoring the NTLDR and Ntdetect.com files from the Windows XP CD usually takes less than 15 minutes
Here's How:
Boot your system  using a Windows XP CD, press any key when the windows display "press any key to boot from CD"and wait for some time, select "r" option to go to recovery console. it will ask you for administrator password too.
When you reach the command prompt type the following two commands, pressing Enter after each one:
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
That's it.
Jan 22, 2010 | Acer Aspire 5315 Notebook
I have a 5 month old acer aspire one with xp and when computer comes on it shows NTLDR is missing, how do we fix this
you will need to run Recovery on it... NTLDR is needed to boot to windows.. if its missing, it won't boot to windows, and unless you have an external cdrom and can throw in a recovery disk or a cd of the same version of operating system and choose to repair.. then fixboot and run chkdsk /r...
To get to your recovery partition press ALT and F10 at boot up
Note: some aspire one's don't have a recovery partition.. and in this case .. windows will need to be reinstalled..
Nov 15, 2009 | Acer Aspire One PC Notebook
Black screen NTDLR Press any key to restart
Are you saying it came with a recovery disk that you dont have anymore. If thats the case you may need to aquire this from acer. If you go to their web site you can usually find a way to order this disc for your machine.
Find someone who has an xp disc and use it to go to recovery console then restore MBR files. NTLDR is the error meaning your master boot record has been damaged.
Char S.
May 27, 2009 | Acer Aspire 5102WLMi Notebook
Acer travelmate 240 notebook - NTLDR missing message
if you had original xp cd, boot from cd then repair you system, otherwise use your recovery cd to give your friend a clear system.
Feb 17, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
Recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Jan 08, 2009 | Acer Aspire 3000 Notebook
Acer "NTLDR is missing" problem
press F10 to enter Bios and make necessary arrangemt to boot from CD rom
Jun 13, 2008 | Acer TravelMate 4150LCi Notebook
Acer TravelMate 2413LCi Notebook Logo
226 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
