Canon MX310 Office All-In-One Printer
Problem for Canon MX310 Office All-In-One Printer
Peoplel are sending me very imp. faxes and idk how to recive it..
By kavitakapila on Oct 04, 2009
how do you recive a fax
Solution #1
posted on Oct 04, 2009
Not Rated)
swDemonDog
Rank: Guru
Rating: 87%, 32 votes
If your printer has FAX capabilities. Good way to tell is if you have a phone number pad on the front of your printer.
You must have this connected to a phone line for it to receive a fax.
Setup the fax application through your installation CD that came with the Printer/fax machine. Often you set the fax machine to pick up after so many rings. This allows you to leave the printer/fax machine on and gives you time to answer BEFORE the fax machine does. If uncle Bob or Aunt Susie should call to say Hi!
Basically what is happening:
You turn on the Printer/Fax machine it sits idle waiting for a phone call.
Someone now sends you a fax using your phone number.
YOUR printer/fax machine is sitting there listening for the phone to ring.
Lets say you have your printer/fax machine setup to answer after 5 rings.
After 5 rings, your Printer/fax machine will pick up and listen for signal tones from the the other machine. If it gets these, it will "handshake" and send a confirmation fax tone. Then the data will be transferred and printed out on your machine or held in a fax program for you to print or save later.
It is critical that you do not pickup the phone too early or the two fax machines trying to communicate will fail.
If you do this, you will hear an awful squeal and a serious of tones.
You can often hang up quickly and the two machines will transmit again the handshake signals and resume business as usual.
Short answer:
Two fax modems are talking to each other over your phone line to transmit data.
and hope this is helpful.
Was this helpful?
Yes
No
Popular Solutions for Canon MX310 Office All-In-One
Questions and Unsolved Problems for Canon MX310 Office All-In-One
Do you recommend Canon MX310 Office All-In-One Printer?
Answer
Answer
when printing something on my cannon mx310, why is the black ink coming out blurry on printing paper
Answer
Hi did you find any solution about the scanner error problem on canon mx310 sgfojib and mammomom???... (More)
Answer
CAnon MX310 alarm CHeck ink U163
Describe your Printers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
