Question about Epson 5550c / 7550c Replacement Projector Lamp - ELPLP07 Projector Lamp
Epson 7550c projector - ELPLP07 lamp fuse.
Anyone know the size rating on the fuse in the lamp housing of the ELPLP07 bulb. It's a tiny fuse (maybe 3/8 inch) but I can't make out any numbers on it.
A main cooling fan broke in the projector causing it to overheat and pop the lamp fuse too. I replaced the fan, so the machine runs nice and cool again. But the "Replace Lamp" timer kicked in from the overheating and there is no manual timer reset I can find, so I think I really only need that fuse. Can't fine the fuse value in any of the 7550 manuals.
Anyone know rating or model# of the tiny fuse?
Thanks...
  • aquatarkus Oct 18, 2009
    After a closer inspection with a powerful magnifier, I found it.
    It is a tiny ceramic fuse. Sadly surface mount soldered.
    100mA (0.1A)
    Example:
    http://www.newark.com/littelfuse/0451-10...
    I confirmed with an ohm meter that it's blown and must have kicked off
    the replace lamp timer.
    Looks like Epson wants to soak you for $300 for the bulb, instead of
    letting you change a $2 fuse yourself. (cleverly done)
  • aquatarkus Dec 03, 2009
    I replaced the fuse, and it's all set.
    Thanks to another posting, I learned that the fuse on this
    model lamp has to blow upon lamp replacement in order to reset
    the timer. If the timer is running, the fuse pops intentionally
    upon installation of the new bulb.
    http://www.fixya.com/support/t520533-eps...
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 729 Answers
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Posted on Jul 23, 2015
Boba
  • 64 Answers
SOURCE: Problem with the lamp
According to Epson the led will flash red in one of two cases: Flashes red with 1 sec intervals - either the lump has burned out(We can rule this one in this case) or the lamps cover is open (try checking the cover's sensor) Flashes red with 2 sec intervals - an internal problem, I'd suggest contacting Epson's support. Good Luck
Posted on Feb 02, 2006
  • 62 Answers
SOURCE: Projector Lamp is flashing Red
if you know how to open the unit, try fixing its ventilation. flashing bulb light sometimes mean an occurance of overheating. try to clean all the fans and the air vent.
Posted on Mar 29, 2009
  • 62 Answers
SOURCE: ELP 3300 lamp problem?
probably. try to check the number of light hours( you can check the manual on how to view it) usually 10000 hours could mean that you need to replace the bulb. also check the physical appearance of the bulb, if it has cracks on the ceramic at the back, then you need to replace it.
tigertail
  • 163 Answers
SOURCE: need to replace the bulb in an epson e71 projector
Hi, this is pretty straight forward. Make sure the projector is off and cooled. On the bottom is the Lamp cover, press the two tabs and lift the cover off. Loosen the two retaining screws and pull the lamp assy upwards to remove. Fit the new lamp and tighten the screws then rfit the lamp cover. You will need to reset the Lamp hours using the "About" menu after turning back on (Not the "reset all" menu).
The user guide can be downloaded from Epson support:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=KBTjt4A8+KgSfbEGuimYvDcGHmpVV+Ko
Posted on Apr 01, 2009
son-of-EP101
  • 24 Answers
SOURCE: EPSON ELP5000 bought from surplus; plug it in and
It is an indication that the projector is in sleep mode. Press power button and check for any changes on the led indicators. If the power turns red, it means unit is hot. check if the fan is working and if the air filter is clean or needs cleaning. If the lamp turns red it means the lamp is busted, You will experience this since lamp is clearly blown. But if both lights are red, it means that the unit is busted and will require service.
Posted on Apr 11, 2010
Do you know if the Epson Remote 151944201 will work for my Epson Projector Emp-6110 also known as 6110i
this remote control works for all the Epson Projector, Have a good day! We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. Jerry Lampdeng Limited
Oct 24, 2014 | Epson Replacement Remote Control Projector...
My argus 300 projector bulb blew new one won't work
yes could have been a power surge at the time, or fan cooler packed it in, the internal housing inside the Projector would have been too hot with the bulb inside it cooling down without the fan, i would double check all parts near the lamp housing and check to see they have not melted or burnt, also worth checking the fuse as well should be a T-250 Fuse bulb
Apr 23, 2017 | Argus Vintage Cameras Inc Projector Model...
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
Does the epson 82c have a reset button? There is no power
there is not the reset button on Epson 82
maybe the powersupply is fault
pls check it
Have a nice day!
Jerry
Lampdeng Limited
Jan 04, 2011 | Epson (V13H010L34) Projector Lamp for...
My EPSON Powerlite 730c projector doesn't power up
epson will not sell parts to anyone who is not an authorized service center. sorry. if you can get the part from an asc, then you can replace it.
Aug 06, 2009 | Epson POWER SUPPLY UNIT: POWERLITE 730C...
Epson EMPS5 lamp light is blinking. Do we need a new lamp?
THIS MAY NOT BE A BULB PROBLEN THIS MAYBE A SINCER PROBLEM A TRANSISTOR PROBLEM CAUSING THE MACHINE TO NOT WORK PROPERLY
IF THE LIGHT FLASH AND HOW MANY TIMES DOES IT FLASH AND WHAT COLOR IS THE FLASH.
GO ON LINE
EPSON EMP-S5 PROJECTOR 5 FLASHING YELLOW LIGHT
ENTER
SEE IF ANYONE ELSE IS HAVING THE SAME PROBLEM AND WAS IT FEESABLE TO FIX IT OR RESOLVE THE PROBLEMS
ROD
Feb 10, 2009 | Epson EMP-S5 Projector
Lamp
Did you reset you lamp hours when you reinstalled you new lamp?
Sep 05, 2008 | Office Equipment & Supplies
Epson 7300
Hi there
The Epson Powerlite 7300's lamp has got a chip on the side of the lamp's bracket that resets the lamp timer automatically when a new lamp is inserted. And it only does it once - first time the unit is switched on after replacing with a new lamp.
The fuse on this chip blows and causes the lamp timer to be reset. Unfortunatelly this is the only way to reset the lamp timer on this model. There is no manual way.
So to cutt to the chase , you will have to buy the original lamp and replace it before it will reset.
Part Number is : ELPLP05
Apr 17, 2008 | Office Equipment & Supplies
Replacement lamp
The lamp you received is correct. I own a lamp replacement company. It may of been pakaged incorrectly or maybe you received just the bulb and not the housing or vice versa (housing included). First, unless housing is damaged NEVER buy a new one...just the bulb will do. Housings are the biggest markup on replacement lamps. They are manufactired at a low cost and usually retailers drive up the lamp price because they include an uneeded housing. The bulb itself (XL-2100U) should be a round bulb. Check out my listing and compare this to what you received:
http://rearprojectionlamps.com/2000u-lamp-p-2277.html
Dec 12, 2007 | Sony XL-2000U Projector Lamp for XBR800...
251 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
