Question about Pit Cycling
Not sparking properly and wont fire - Pit Cycling
    Problem Solver:
  • 7 Answers
Try a warmer plug.. and clean of magneto
Posted on Oct 05, 2009
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
Atv wont start
small engines need 3 things..gas air and fire(spark)..is this electric start or pull rope? makes a difference in the answer..repost..
Dec 08, 2013 | ATVs
2000 chryler concord trys to fire but wont start can smell gas though 2.7 engine
Was the car running and quit or would it not start after setting?
Jan 12, 2013 | Cars & Trucks
Wont start not fireing
Not firing you will need to open your hood and disconnect your ignition coil and remove retainer bolts using the proper socket once removed replace and reinstall all ignition wires you should now have spark
Jan 21, 2011 | 1992 Toyota Celica
Engine missing wont fire properly, i think its the spark plugs how do i change them ?
CHANGE SPARK PLUGS.YOU NEED SPARK PLUG 3/8 SOCKET.YOU NEED SHORT AND LONG 3/8 EXTENSIONS.YOU NEED SPARK PLUG BOOT PULLER AND A SPARK PLUG GAUGE SET THE SPARK PLUG GAP.NOW CHANGE 1 SPARK PLUG AT A TIME SO YOU MIX THEM UP GET FIRING ORDER MIX UP CAR BACK FIRE WONT CRANK.ALSO CHANGE PLUG WIRES ALSO.
Nov 10, 2010 | 1994 Honda Civic
93 gmc jimmy wont start turns over and theres spark but it wont fire. fuel pump sounds like its priming
spray ether into intake , if it wants to run then you have a fuel problem. if you can rent a timing light, check the timing, it could have jumped, and it will still have spark. also check the plugs for proper gap.
Jun 21, 2010 | 1993 GMC Jimmy
2007 PONTIAC VIBE CRANKS, BUT WONT FIRE.
it is still under warrenty. take it back to the dealer.
Jan 28, 2009 | 2006 Pontiac Vibe
Daewoo lanos 2000 car is misfiring and wont run properly firing on cylinders 1 and 4 misfiring
have you changed the ignition wires? perhaps firing order crossed? if not coil pack or ignition wires faulty how do you know it is not "FIREING" on 1 & 4 have you tested it with a spark tester tool???
Dec 23, 2008 | 2000 Daewoo Lanos
Backfiring a little and wont start up
did you check the spark plugs? try that maybe you are not getting proper spark and thats why you are back firing and it is turning off.... i would recomend changing plugs and wires.
Sep 22, 2008 | 1993 Mazda RX-7
Cycling Logo
62 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
