Question about Kenmore 62602 Electric Dryer
Dryer belts seems to be squeeling when running. should I replace it?
  • 464 Answers
It could be the drum belt and or the drum support rollers. both are wearable parts. look for cracks in the belt, if there aren't any it is likely ok. try replacing the 2 drum support rollers.
Posted on Oct 04, 2009
The dryer squeels when operating and I put some belt grip on the belt. It helped for a little while but now it's worse than ever. The belt feels pretty snug. ???
This could be a few things. The idler pulley or drum rollers are the likely problem. Both are easy to check and replace. The belt should be replaced at the same time. Here is a couple links that should help
Dryer belt replacement video
Dryer roller replacement
Noisy Dryer
Dec 03, 2010 | Magic Chef CYE3005AYW Electric Dryer
Drum makes a squeeling noise
it pulley or there is two support wheels for drum.
you can oil them, but wheels could be broken and have to be replaced.
appliancesrepairla.com
Jun 26, 2010 | Maytag MDG9606 Dryer
Squeeling noise as dryer is running
The belt tensioners pulley has a worn bearing. Replace the belt along with the roller for the tensioner at the same time. Remove the top panel then the front panel to remove the drum to access the worn items
May 09, 2010 | Dryers
11087088601 dyer squeels at start; will stop after a bit
The belt is loose and is most likely due to the belt being stretched out. Replace the belt and the tensioner also to solve this squeal.
Apr 14, 2010 | Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool dryer, elctric runs but squeels. sometimes it stops squeeling once it's run for a while but lately it seems to do it the whole time. it does get quieter after it's run for a while
sounds like your "Drum Glides" need replacing, open the door and cheat the door interlock and you should be able to hear it closer by bottom of drum by lint filter if yours is located there depending on model
Jul 28, 2009 | Dryers
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Dryer is making a loud squeeling noise when running
This is probably the drive belt slipping on the drum or motor. There is usually no adjustment on these and it is a case of replacing the belt. If you take the top off the machine, you may be able to look inside while it is running (KEEP CLEAR OF THE ELECTRICS AND DO NOT DELVE INSIDE WHILE THE MACHINE IS IN THIS STATE!) and see the belt slipping. If it is, it's probably time for a new belt
Nov 20, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Kenmore 62602 Electric Dryer Logo
70 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
