Question about Dishwashers
Hello, My Kitchenaid dishwasher has water coming out of the drain valve which is located on top of the sink. I figure that something might be clogged. Suggestions on how to approach this? Where would I find the model number? Thanks
  • 464 Answers
Look around the edge of the tub opening where the racks pull in and out for the model #
Posted on Oct 04, 2009
Kitchenaid dishwasher wont drain
Allow the current cycle to complete. Draining will occur at the end of the cycle.
Close and latch the door. The dishwasher will not drain if the door is not properly secured.
Press the "Cancel/Drain" button on the dishwasher to start a two-minute drain cycle.
Remove the knockout plug in the disposer outlet of the garbage disposal if the dishwasher drains into the disposal. Turn off the water supply and remove the drain hose from the disposal. Place the tip of a screwdriver on the plug and tap it lightly with a hammer to remove it. Replace the drain hose and turn the water supply on.
Clogged Drain
5
Run the garbage disposal to empty it and clear the drain if the dishwasher drains into the disposal.
6
Remove the cover on the air gap on the sink or countertop. Turn the plastic cap counterclockwise to remove it. Remove soil from the inside of the air gap. Replace the plastic cap and cover.
7
Check the sink. Dishwashers connected to a sink will not drain if the sink drain is clogged. Unclog the sink. Contact a plumber, if needed.
Issues With the Drain Hose
8
Check to see if there is a loop in the drain hose. The loop cannot be more than 20 inches above the floor. Disconnect the hose and loop it just above the floor. Reconnect the drain hose.
9
Remove kinks in the drain hose. Always use the new drain hose included with the dishwasher. Do not reuse old hoses.
10
Check the length of the drain hose. The hose should be less than 12 feet long. Replace with a shorter hose, if needed.
Sep 01, 2012 | KitchenAid KAWS850LE Top Load Washer
Electrolux dishwasher overflows
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 09, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
Dishwasher doesn't drain properly
Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up.
GA_googleFillSlot("HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250");
GA_googleCreateDomIframe('google_ads_div_HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250' ,'HT_Appliances_Dishwashers_Articles_Box_Top_Left_ATF_300x250');
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.2) Once the dishwasher is cool, shut off the power to it, and-if your dishwasher is made to allow this-remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). dishwasher_er1.gifUnscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
Thanks for using fixya.
Nov 02, 2010 | GE 24 in. GSD4320Z Built-in Dishwasher
Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Mar 17, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Water comes back into the washer from the sink
If this is happening it is because your dishwasher is plumbed into the drain wrong. Even if the drain is slow or slitghly plugged you still should not have this problem.
The drain from the dishwasher should go into the sink tail piece high up under the sink with a "Y" fitting. The drain hose should also loop up higher then the bottom of the sink at some point. This should keep the water from the sink from backing up into the dishwasher.
You need to either check the drain yourself and reroute it or have someone doit for you.
Heatman101
Feb 13, 2010 | KitchenAid KUDS03FSSS Dishwasher
Is it common for Kitchenaid dishwashers to have water pooling inside them? It's almost like the valve for water coming in isn't shutting all the way...in the middle of the day, we'll find water inside the...
There is a rubber flapper valve that keeps water from running back into your dishwasher. It's a $5.00 part, but it's a bear to get to,
You have to pull the drain pump to access this flapper.
Also, be sure your air gap is clear (usually the silver tubular gizmo on top of the sink.
Jun 09, 2009 | KitchenAid 24 in. KUDP02FRSS Stainless...
Only motor goes on, no water
Hi,,
try these
  1. Check that the water supply is turned on. The valve may be located under the sink.
  2. Check the door latch
  3. Test the door switch
  4. Inspect the float assembly
  5. Inspect the fill tube for kinks
  6. Test the float switch
  7. Check the inlet valve filter screens
  8. Test the water inlet valve
  9. Test the drain valve lever arm
  10. Check the drain valve
  • please rate my suggestion....
Apr 11, 2009 | KitchenAid Dishwashers
KitchenAid Dishwasher fill up with water after use
Is the water clean water or dirty water? This may sound like an ignorant question, but it can make a difference. If the water is clean water, it sounds like you could have a bad fill valve. If the dishwasher is filling with water when it is not running, chances are the fill valve is leaking. The valve is closed when the float switch senses the tub filling to a certain level. The valve is also closed when not energized by the control board during drain, drying and off cycles. However, if the valve diaphragm is not seating properly when closed, it will continue to leak by. That's probably why you don't notice it while is running and it has a chance to fill during the night when not in use. Here's what to look for: With the dishwasher off, take a towel and dry the tub as much as possible. Now, locate the fill port where the water comes in (usually on the left hand side of the tub). Watch this fill port closely for several minutes to see if water is running in. It could be as minute as a trickle or drip. If any water is coming in at all, the fill valve should be replaced. Now, another problem that can occur is when you notice dirty water staying in the tub or overflowing. This is usually caused by a bad check valve in the drain pump that's allowing water to leak back from the sink into the tub. Or, you do not have a high loop in the drain line. Here's what to look for: Check to make sure the drain line has a high loop as it leaves the dishwasher and before it gets to the drain pipe at the sink. That is, make sure the drain hose is looped above the trap in the sink and not laying under the sink somewhere. You can also try filling the sink with water and open the dishwasher door. Drain the sink to see if anything is getting fed back into dishwasher. If you see water starting to fill in the tub, chances are you could have a bad check valve. Some dishwashers have a check valve in the drain pump, while other models have the check valve located in the drain hose itself. Some don't have one at all. That's why the positioning of the drain hose can be important. Good luck to you and I hope this may help. If you determine a cause, post back with comments if you need advice on how to replace anything.
Sep 22, 2007 | KitchenAid 24 in. KUDS25 Built-in...
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
