Question about Milwaukee Tool 1 - 1/2" SDS - max Rotary Hammer
Remove broken drill bit - Milwaukee Tool 1 - 1/2" SDS - max Rotary Hammer
  • David Ford
    David Ford May 11, 2010
    what is the brand and model number and I will see what I can do to help
  • 94 Answers
Soak the chuck area real good with W/D40 or similar,position drill so lube doe's not drain .let sit for awhile, then turn upside down and gently whack it about, worked 4 me,
Posted on Apr 21, 2010
Type of drill bit to drill a file by hand drill
Your best bet is to look for either Carbide tipped drill bits or Titanium drill bits. The broken round file is most likely hardened steel.
Jan 18, 2017 | Cars & Trucks
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
How do i remove a broken harmonic balancer bolt in my 1999 mitisubisii montero sport
are we talking about one of the small bolts that hold a belt pully onto the balancer? Or the large bolt in the middle that holds the balancer to the crank? Either one will be the same procedure, but if it is a small bolt and proves troublesome to get to, you can always remove the balancer and take it to a machine shop to aide you in the removal. If it is the main bolt in the crank shaft you will have to do it in place.
You will need a good sharp center punch and hammer to ding the exact center of the broken bolt. Then a good drill bit and drill set on slow (you drill too fast and you generate too much heat you just accomplish work hardening the broken bolt and dulling the bit.) anyway, you will also need a bolt extractor. Make sure your drill bit is the right size for the extractor and the extractor is the right size for the bit. Punch the dead center of the bolt and start drilling you will want some high temp oil to lube the bit and keep it cool while drilling, you also need to make sure that you hold the drill at a right angle and keep it straight all of the way in until it is deep enough for the extractor to grab the inside of the hole you have made. Strike the extractor solidly with your hammer to set it and cross fingers that when you try to back the broken bolt out it moves. If this fails you might need to completely drill the hole larger and install an insert, or heli-coil to repair the hole.
Aug 03, 2014 | Cars & Trucks
Broken drill bit stuck inside drill
if you open chuck all the way the drill bit should just fall out
Dec 11, 2013 | Bosch 13624 24V Cordless Hammer Drills
How to get a broken drill bit out of the crank pully shaft ona 95 Dodge Neon???
Unfortunately you might be in need of an expert. Drill bits are hardened, unlike your crank shaft. A machinist is usually well versed in broken bolt removal and they might just have an ultrasonic extractor. Getting a broken off hardened anything in usually not something I would recommend to the un-experienced.
Apr 21, 2013 | Cars & Trucks
I broke the crankshaft bolt what do i do?
ok witch bolt is it. On most tuff bolts that I break trying to remove or install I use a left hand drill bit and then if that does not catch and remove I use an easy out but let it soak for a while with some WD-40 first
Dec 17, 2010 | Chevrolet Impala Cars & Trucks
Sd rotary hammer drill 110 volts bit brocken in chuck
Put some WD40 into chuck and wait a few minutes. Open the chuck as you would do when normally removing the drill while at the same smartly tapping the back of the drill.Alternatively try to grip the broken drill bit with a long nose pliers to extract it. A strong magnet might also pull the bit out.
Nov 08, 2010 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Can't get broken hex bit out
what you need to do is remove the quick release mechanism. there is a retaining ring DO NOT STRETCH then a small flat washer and spring lift the collar and there are usually 2 small steel balls. then using a magnet you should be able to remove bit. this works only if the shank on the bit is not twisted.
Aug 23, 2010 | Dewalt DW056 18 Volt Cordless Impact...
How to remove a chuck from a DeWalt hand drill
Open chuck all the way (like for a large drill bit). There should be a set screw at the bottom (where you would put a drill bit). Don't turn too hard - it may be a left handed screw (I don't remember if it is a lefty for sure but try gently each way then with a bit more force each way until it moves).
Good luck.
Mar 19, 2010 | Dewalt DC925B Heavy Duty Xrp 18V Cordless...
Broken crankshaft pulley bolt on mitsibushi pajero 2.5td 1993 rhd automatic.how to remove easily the broken part which is in crankshaft,pulley is off
The only possibility I can suggest is that which is called and 'Easyout.' These are available at parts stores and come (normally) with a sized drill and a special bit with left-hand threads.
First a hole is drilled with the provided drill bit, then the removal bit is screwed into the new hole and turned counter-clockwise which further inserts the removal bit and, if the removal bit does not snap, the broken threaded shank should back out.
I would suggest soaking the broken part with penetrating lubricant first and allowing it time to seep into the threads of the broken bolt.
Oct 13, 2008 | 1998 Mitsubishi Montero
Milwaukee Tool 1 - 1/2" SDS - max Rotary Hammer Logo
460 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
Harjeet Singh
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
