Question about Nuova Simonelli Mac 2000 Espresso Machine
Hey, my espresso machine doesnt brew a shot the whole time.. it stops short.. just one side.. other side is fine
    President:
  • 1,618 Answers
Does it do that with all the buttons on that side or just a particular button. If all buttons then there is a leak on the steam valve on that side of the machine that is dropping water on the keypad.
Posted on Oct 05, 2009
The grinder works but coffee too light in colour and no foam
You didn't indicate what model you are using but it could be several things.
If your coffee isn't ground fine enough your brewing time may be too short. Your double espresso shot should take between 18-26 seconds to brew. A single should take between 9-13 seconds to brew.
If you are getting the correct brew time, try a different coffee bean. Some coffee is roasted more that others and that could be the reason the color is light. Make sure you are using fresh beans too.
Make sure you are putting the correct amount of ground coffee into the porto filter and tamping it well. A porto filter that isn't full will not brew a good shot.
Sep 22, 2016 | Faema Coffee Makers & Espresso Machines
Coffee side beeps 3 times and does not brew. Espresso side and frother are fine
KRUPS XP2280 Espresso Machine and Coffee Maker ...
www.amazon.com/KRUPS-Espresso-Combination.../B...
Amazon.com, Inc.KRUPS XP2280 Espresso Machine and Coffee Maker Combination with ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
KRUPS XP2280 Espresso Machine and Coffee ... - Amazon
uedata.amazon.com > ... > Espresso Machine & Coffeemaker Combos
Krups is pleased to present our new XP2280 Combi Espresso and Coffee ... Theespresso side is literally idxxt proof with the built in tamper system and ... Theespresso does not brew after waiting for the light to turn solid and simply pushing 1 or two cup selection. I often have to push 3 or more times and it still doesn't work.Missing: beeps
Troubleshooting Semi Automatic Espresso Machines
www.espressoplanet.com > Articles > Support > Troubleshooting
Oct 24, 2010 - We do not encourage anyone to open up the machines and try to repair them and if you ... (The water will be moving through the holes between the coffeegrounds ... The portafilter doesn't stay in place in the group head while brewing. ....Jura, Solis, Saeco, Krups, Capresso, Gaggia, Rancillio, Nespresso.Missing: xp2280 ‎side ‎times
Jan 28, 2016 | Krups XP2280 Combi Espresso & Coffee...
I seem to not be able to figure out the button sequence for programming the shots.
Try pressing and holding the button until the quantity is what you want it to be. Then try it again with just the normal short press to start. If it brews the same quantity as the first one then it is now programmed.
Jun 20, 2015 | Coffee Makers & Espresso Machines
Sunbeam em6910 brewing does not stop
Use a bigger glass or cup . easiest fix I can thnik of
Jan 10, 2015 | Sunbeam Cafe EM6910
I have a Incanto Classic. I put in whole beans and it brew the first shot without a problem (the puck formed after) . I have since tried it again and no espresso (liquid) comes out. The grinds were...
Hi
The small knob in the bean hopper is set to the max or + side. Turn the small knob back 1 mark and try again.
http://www.fixya.com/support/r3658318-superautomatic_not_make_espresso_dumps
Sep 19, 2011 | Saeco Incanto Classic Espresso Machine
My lavazza espresso point capsule machine has stayed plugged in and working for almost 2 years. Now it turns itself off after being on a short time or after brewing a few shots of espresso. If I turn it...
The only possibilities I see here are either the Plug Holder with Fuse Block which sometimes goes bad and periodically will shut down the unit. The other possibility is that the Electronic Card has gone bad. It over-heats and shuts down power.
Jun 01, 2011 | Lavazza Espresso Point Capsule Machine
Cold shots
Remove the portafilter and press the brew button is the water that is coming out of the head warm or completely cold? If cold then one of the thermostats on the boiler is damaged.
Aug 09, 2009 | Gaggia 102534 Espresso-Color...
Jura S9 Capresso Machine "Fill System" Message
I think you use too fine grist on the grinder, or the coffeebeans are really dark and moisty. Try to set the grinder to a coarser grist, for dark roasted coffee it`s not recomended to to use any finer than medium grist. However, the sieve in the brewing unit could be clogged, and you need to clean this out. Put a finger up in the brew unit just along the grounds blade, you will probably find a lot of old fine coffeeground up the. Clean it up as best as possible, and then try to make coffee with coarser grist. If this helps, it`s smart to run a cleaning program to be on the safe side.
If nothing of this helps, you don`t have a choice, you have to send it for service, then the brew unit has to be dissasembled and cleaned from the inside.
Jan 28, 2008 | Jura Capresso Impressa S90 Espresso...
Water flow
You will have to adjust your shot timing, and possibly your grind. To program the shot timing, hold the Brew Stop button until all of the brew lights come on; That means all of the buttons are ready to program. Next, pull some grind for your portafilter and push the button you want to program. For a single, you want to pull a 1 oz shot in about 15-20 seconds; longer for a double. When you push the button, the shot will start to pull; when the shot is complete, push the button again to set it. Then do the same for the next button. Each group needs to be programed separately. Holding the the Brew Stop button again will turn out the remaining lights and save your programming to that point. As to the grind, you want to have the grind fine enough to give you a quality shot in the right amount of time. Good Luck!
Oct 13, 2007 | Astra Mega II Espresso Machine
Nuova Simonelli Mac 2000 Espresso Machine Logo
88 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
