Question about HP PSC 1350 All-In-One Thermal Printer
My Hp 3 in 1 printer does not want to scan, how can I fix this?
5740 hp officejet printer streaks on scan or copy
The glass is smudged or dirty or the scanner bar may have dirt on it. Cheaper to just replace the machine.
Aug 19, 2016 | HP DeskJet 5740 InkJet Photo Printer
HP Laser Jet 3055 is showing scanner error 6 and Comm. error 386, 232, & 388
This is due to a hardware failure, the scanner assembly and the formatter board will need to be replaced.
NVRAM INIT
1. Turn off the all-in-one
2. Press and hold down the * and enter buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. Allow the all-in-one to return to Ready before using it. storage init. appears, and then release the buttons.
if this does not work contact hp 1800-334-5144.
Al
Eliteprintersolutions@gmail.com
Jun 14, 2010 | Office Equipment & Supplies
Scanning from the network
Dear Friend,
Install the printer driver on your computer and than download fix scan utility from Hp.com. After installing fix scan utility You will be able to scan.
You have to do the same on every computer from where you want to scan.
Regard
Under Trainee
Dec 17, 2008 | HP LaserJet 3055 All-In-One Printer
Can't scan with HP Officejet 6110 from document holder
well u can try:
1/uninstall and install printer/scanner drivers and software.
2/ replace the usb cable.
3/make sure that there is no damage va been maen on th AIO cuz u need a warrantly in this case.
plz do rate this post.
Dec 12, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1610xi Will not scan have installed software manytimes to no avail. the unit will start to scan and then locks up. have to unplug power to unit toget unit up again and then indicates unit is...
If you are having problem whit your scanner/printer, do the following:
1) Uninstall the printer,
2) Delete all the printer folders created during the last installation.
3) In the computer registry (start >> run >> regedit.exe) Delete all printer paths
4) Reboot your computer
5) Re-install the printer again.
This will fix your problem.
Oct 08, 2008 | HP Office Equipment & Supplies
I need some help please....
Sorry it is not a backward 3 it is the letter 'E' (for error) please try the steps metioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00861481&dlc=en&product=306888
Good Luck
Aug 07, 2008 | HP PSC 1350 All-In-One Thermal Printer
Trying to scan, but keeps on saying "USB not connected"
I had the same problem.  The thing is I was pressing the scan button on the printer and getting the lovely "USB not connected" message.  However, if you open the printer icon in the dock (Mine is "HP Photosmart C4200 series") and click the Scanner button in the upper right hand corner, then click "New Scan," voila!  presto! and all is right with the world again.
Yes, it is obnoxious that HP made a defective scanner button, and I may download the driver again when I get a chance.  But yay for quick fixes!
Feb 06, 2008 | HP Photosmart C4280 Aio Printer
HP Officejet 5610 All-in-One scanner will not work
Windows Vista causes an error with the scan feature of the HP officejet 5610. To work around it use the paint program:
1. open paint program
2. click file
3. click "from scanner or camera..."
4. scan menu opens
from there simly select the type of scan you would like to do and click the scan button
Jan 07, 2008 | HP Officejet 5610 All-In-One InkJet...
HP PSC 1350 All-In-One Thermal Printer Logo
29 people viewed this question
Ben Johnson
