Agitator does not move. Tub does spin. - Washing Machines
  • 464 Answers
Get the make and model of machine and I will help you from there. every machine is built different.
Posted on Oct 04, 2009
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
I have a LG WT5001CW top load washer. Recently the agitator plate began to loosen and fall off during spin cycle. Now when spin cycle starts and the tub turns it squeaks and grinds then I get a UE alarm.
The agitator has a gear like attachment that meets the long shaft up the center of the tub. If the alignment is off and not exactly in place the agitator will move or the gear-like part will wear down, become rounded, or break. The agitator must fit perfectly and tight. A nut on top (under the cap) has to be turned down tight.
Feb 27, 2014 | LG WM0642H Front Load
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
My maytag won't spin. The agitator moves but the
Sounds like the transmission is shot. Call a repair shop, or buy a new one.
Oct 21, 2009 | Maytag Performa PAV2200
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
May 26, 2007 | Maytag PAV2300 Top Load Washer
Wheezing sound
The inside tub moves on the spin stage only and cause the water, by a centrifugal force, to be forced out of the clothes. During the wash cycle,the tub is stationary and the agitator moves forth and back. If you would like to remove the agitator - Remove the inner agitator cap (inside the top of the agitator) and then open the screw (be aware not to lose parts !) Good luck !
Jun 11, 2006 | Whirlpool LSQ7533JT Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
