Question about Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac
Need to take the hose assembly out of delta 470 faucet
I need to take the hose assembly out so I can replace it. It is stuck when pulling from down
  • 127 Answers
You need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Posted on Oct 18, 2009
  • loafmom Oct 07, 2010
    I am also having the same problem with my delta faucet. I HAVE removed the weight, and have been told that the hose should just pull through, but it gets stuck either way? I am not worried about cutting and removing the one in there, but I am wondering if I can get a new one through or will have the same problem? Has anyone had this problem and found a solution? Thank you!
Delta 470 trying to remove metal pull out spray wand but it gets stuck when trying to remove and replace
Are you trying to just replace the sprayer? I replaced the whole unit so cannot help with just the sprayer.
Jun 08, 2014 | Delta Faucet Delta 470-BL-DST Signature...
Hose assembly
Shut off main water to home. Then check if a clip is guarding the nut to nut threaded connection the use 2 wrenches to un screw.
Cover tools "teeth" with tape or thin rubber to prevent marking on chrome/etc finishes.
Jul 29, 2013 | Delta Model 470: Signature Kitchen...
How can I remove wand to replace hose on Delta signature series 470 model. Can't "unscrew" wand from old hose.
Go ahead and buy the new hose ant it will come with installation instructions and you will see how it comes apart at that joint.
Feb 10, 2011 | Delta Model 470: Signature Kitchen...
Very low pressure on delta 470 faucet
To get full pressure you need to pull the wand away from the base. Then remove the wand from the hose becareful not to loose the washer. When the wand is removed look down the wand you will see a plastic part. That plastic part is a flow restrict-er. You need to put a screw in the restrict-er and pull it out. When it is out put wand back on the hose then you will have full water pressure.
Jan 16, 2010 | Delta Faucet Delta 470-BL-DST Signature...
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Delta Faucet 470-DST Signature Diamond Pull-Out Spray Kitchen Faucet - Blac Logo
857 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
