Question about Panasonic Lumix DMC-FZ30 Digital Camera
Will not power on. Was on beach at Yorktown,Va, turned it off and set camera down on concrete wall and when I picked it up it would not power on!
Which deck building contractor is best to hire in Virginia?
For deck building you can check Paragon remodeling contractor work from here: http://www.paragonremodeling.com/deck-portfolio/index.html. These deals in North Virginia area.
Sep 21, 2013 | IMSI Software Turbo Floorplan Instant Deck...
Need drivers for a gateway yorktown 0028655540
These can be found online at their website gateways that is.
Sep 26, 2012 | Intel C11812-102 P4 478 Pin Yorktown...
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
2009-10-05 I have a motor in my garage that serves my water softener, sprinkle system, and outdoor faucets in conjunction with a well pump. I live in Virgina Beach, VA. The motor is an A.O. Smith machine...
sounds like just pressurizing ur holding tank pumps come on and off depending on how sensitive ur pressure control is normal operation of unit
Oct 07, 2009 | Plumbing
Problem with M340 Kodak easy share digital camera..( automaticall
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Aug 17, 2009 | Kodak EASYSHARE M1063 Digital Camera
The Beach
You may want to call Olympus Customer Service and discuss their repair process and procedures for sending the camera in to have the lens assembly cleaned. Their telephone number is 800-622-6372 option 2 and then option 3
Jan 09, 2009 | Olympus FE-190 Digital Camera
Lens Error.
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Jan 02, 2009 | Nikon COOLPIX L18 Digital Camera
Grainy photos in sunlight
Your ISO is probably set too high? to change iso press the fn (function) button and select the right option (with the right arrow) to go to the iso menu. Then use the up and down arrows to change the iso setting. I don't go higher then 400, and in the beach you could set it way down to 100.  Don't point the camera in the direction of the sun as this can wash out the photo. A filter would help somewhat.
Aug 09, 2008 | Pentax K110D Digital Camera
Panasonic Lumix DMC-FZ30 Digital Camera Logo
23 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
