Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Need to light pilot light?
Oven won't heat up - need to find out how to light pilot light.
  • 464 Answers
Does the gas ignite at all. you shouldn't have to light a pilot. if the oven is not igniting you most likely need an ignitor or glow coil as it is sometimes called.
Posted on Oct 04, 2009
Heat and Glo pilot light works but Burner won't go on. I messed with it and it started up but won't turn off. next day won't start but the pilot light is still on
light your pilot and take a light to the termopile (right beside your pilot it sticks out to get heat from your pilot. hold lighter for 5 seconds and turn gas on
Dec 08, 2012 | Napoleon 36" Zero Clearance Top/Rear Vent...
Stoves 61gdo main oven not lighting
the thermocoupler is at fault it will need replacing if its stuck on pilot the thermocoupler heats up a small capilary tub that swiches the control to the temp regulator
Nov 23, 2011 | Kitchen Ranges
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
Burners work fine, pilot light in oven is on, but oven won't ignite
Make sure the thermocoupler is being heated by the pilot light flame. It could also be gunked up but you can clean it with a scouring pad, or it might need to be replaced. The thermocoupler is the most likely cause because if it isn't heated then the gas valve will not open up and no gas will flow to the burner. Since your pilot light is on then you do have gas to the valve.
Aug 28, 2011 | Ovens
GAS TO STOVE WAS TURNED OFF FOR COST SAVINGS BECAUSE NOT USED. OVEN PILOT LIGHTS WON'T LIGHT CAN'T SEE WHERE HOLE FOR LIGHT IS SO TO BE CLEANED??IT LOOKS LIKE A BLEEDER VALVE FOR BRAKS IS HOLE AT...
To light those pitots remove oven floor& access panel below the doors,for each oven will be a gas valve inside of the panel below the doors and has a red button. push that red button,light pilot inside of oven near the main burner,hold red button for 30 seconds and releas.Pilot should be on,repeat for other oven. If pilots go out after red button was held down for 30 seconds the part called the thermocoupler will need to be replaced
Aug 18, 2011 | Garland H283 Gas Kitchen Range
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Electrolux chef oven.. pilot light on but the oven is not heating up
I need more information to help you, first of all, to the bast of my knowledge I thought all there units were light but ignitors not pilots. I need a model number to verify. Also if the ignitor comes on just because it glows does not mean it is strong enough to open the safety valve and allow gas to enter the burner. I use a meter to determine that issue, it needs to be 3.2 to 3.6 amps to open, if ignitor is running at 2.8 amps it may work sometimes, if lower, it won't work at all just glow.
I would need a model number to get you more information, looking forward to assisting you further...
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 15, 2011 | Ovens
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
Kenmore gas oven model no. 273 3248296 pilot free ignition wont fire up
Hi
If it won’t fire then it is possible that the oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
The flame needs to heat the bulb up enough to tell it to open the gas valve. Several things can go wrong here that keep this from happening:
The pilot flame may not be hot enough, usually because the flame is yellow instead of pure blue or is too small. The cause for this is usually a dirty pilot assembly. The pilot assembly would either need to be cleaned or replaced.
The thermocouple bulb may not be positioned properly in the flame. You can't heat the bulb properly if it's not in the pilot flame! The thermocouple bulb needs to be in the upper third of a pure blue pilot flame--that's the hottest part of the flame.
The thermocouple itself may be burned out. It happens. It's an internal part of the gas valve so, no, you can't just change the thermocouple bulb separate from the gas valve.
But when you turn on the oven or the thermostat calls for heat, the pilot flame gets bigger and jumps down so it can heat up the thermocouple bulb. This extra gas to increase the pilot flame size comes from the thermostat.
If the pilot flame jumps upwards or just gets bigger, but doesn't shoot down, then you need to replace the pilot assembly.
If the pilot flame size does not increase or jump down when turning on the oven thermostat, then the problem is the thermostat not sending enough gas to the pilot assembly. It's also possible that the pilot gas supply tube has a hole in it somewhere.
One final point on the spark-assisted pilot ignition systems. The spark comes from the spark module--the same module that sends spark to your surface burners to light them up. If you're not getting a spark when you turn the oven on, then there are several possibilities:
There could be a problem with the switch in the thermostat. You can confirm this by doing a simple continuity test of the thermostat contacts. If you don't read zero ohms when you turn the switch on, replace the thermostat.
The spark module could be bad. You'll need to measure the voltage at the oven terminals of the spark module when you turn on the oven. If you get 120v but no spark, it's probably a bad spark module. Replace it.
Could be a bad spark wire or broken electrode.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Ovens
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
398 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
