Question about Gateway FPD 1510 15.1" Flat Panel LCD Monitor
My monitor has lines going all across the screen, and areas of the screen are different colors. is this fixable
    Scholar:
  • 50 Answers
Make sure it is the monitor and not the video card. I have seen bad video cards display the same symptoms and their drivers. I would test this on another computer before going any further. If it is still the same you know it is the montitor. I do not fix monitors nor do I know of anyonw who does but in my experience it is more costly to fix than to re-purchase.
Don't forget to call the manufacture and make sure that this is not covered under warranty, if it is still under warranty.
Posted on Oct 04, 2009
Screen was working, then al of a sudden I have horizontal lines in one-inch blocks of different colors across screen?
looks like a case of overheating lcd panel tab board..you might have a loose TAB.. contact your nearest LCD repair center..
May 08, 2010 | HP w1907 LCD Monitor
Black & White lines across my monitor
1.Make sure all the connections are secure.
2.Try attaching the monitor to a different PC if possible, to determine if its the monitor or video card.
3.Your monitor might just be going bad
Jan 04, 2009 | LG Studioworks 900B 19" CRT Monitor
Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Nov 06, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Heavy white lines accross the screen
change the ram and viedo card agian
Jun 07, 2008 | Computers & Internet
Solid line completly across screen, monitor is brand new
Your comp's video card refresh rate (in Hertz, abbreviated Hz) may not be totally compatible with the monitor. Check the properties of your video card, and change the refresh rate (you may have to look around for it) to 60 Hz. This is a pretty standard refresh rate that works with just about every monitor. If it's already there, I'm afraid someone else will have to try and help!
Hope this helps, and please rate my answer, good OR bad.
Feb 04, 2008 | ViewSonic OptiQuest Monitor
Fuzzy area on right side
I also have this same problem.... I took the thing apart blew the dust out and put it back together..... no change. I was not able to fix the problem, but if you go into the color settings you can tweak back the red and green to the the heavy distortion to go away. It is almost unnoticeable now.
Good luck
Brent
Nov 12, 2007 | Dell UltraSharp 1905FP 19" LCD Monitor
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Gateway FPD 1510 15.1" Flat Panel LCD Monitor Logo
283 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
