Question about ViewSonic VX900 19" Flat Panel LCD Monitor
My monitor will turn on for less than a second, but then will go completely black. I've tried unplugging it and checking the connections, but nothing has worked.
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 152 Answers
Mrtyler7, With monitor connected to a KNOWN GOOD pc that is displaying the WIN-desktop, then and only then turn-on the Viewsonic VX900. Note what happens. After LCD screen BLACKS out tell me if the desktop can still be seen if you point a bright flashlight 1 inch form screen??? You may or may not see the desktop depending on how far the "switch-mode-power-supply" has gone into SHUTDOWN mode to try and save it's self from a catastrophic faliure. Get back to me with result of test on fixya or by email. Also check out YOUTUBE for short video clips on "lcd monitor disassembly" or "lcd repair" or search web for stuff like "swollen caps" or "badcaps.net" or "bad electrolytic capacitors" !!! You may fall into this type of failure catagory. Let me know what plan of action you will be interested in. I will also let you know what other options you have. I'm louie12fix on fixya or lmistyrel@aol.com
Posted on Oct 04, 2009
Display not working, power button LED turns on blue for 1 second and won't turn on again
Have you tried checking with another monitor. Meaning that if the second monitor does not come on then the problem is with your computers mother board. But if the monitor other monitor you check it with comes on then of course it is your monitor.
Jun 12, 2016 | Acer 22" X223w LCD Monitor
My I plugged in monitor the yellow light on just less than 1 second. then it off and monitor do nothing. no display, just black screen as in unplugged state. This my favorite monitor. I checked horizontal...
Hi, please consider that you have an issue with power supply of your CRT. Before checking any possible active components on it, first check the power switch. Then proceed to check power capacitor in the power supply.
Jan 19, 2014 | Philips Professional Brilliance 109P...
Hi, I have a Princeton LCD17D flat screen monitor and the screen keeps going black after 20 seconds or so. I power up my PC and it turns on then black. If I turn it off and on again the same thing occurs....
It's getting power, it's just not getting signal from the data cable. The cord that connects to the monitor, (not the power) is typically the reason it is going into standby mode. This can also happen if your graphics card driver is missing on your operating system, but you said you tried the monitor on another machine, so I narrowing it down to most likely be the data cable. Try another cable.
Jan 09, 2012 | Computers & Internet
The monitor does not power up. no power light comes on, there is nothing that shows up on the screen. All cables are well connected and yes the power switch is on.
check by changing the power cord if this does not solve the problem the fault is in the power of the monitor better call technician or take it to the service centre
Aug 02, 2011 | Samsung SyncMaster 940UX LCD Monitor 19...
It won't turn on -
hi there, it sounds like your monitor isn't receiving power, check the power cable in your monitor is connected and not partially unplugged. Second, if that doesn't work, try looking at your plug and make sure that is plugged in. If that doesn't work, you may have to buy a new monitor or give it to a friend that can repair it.
Jan 19, 2010 | NEC 1760VM (Black) 17" LCD Monitor
Monitor turning black
the backlight fluorescent bulb is burned out.
Dec 26, 2008 | Computers & Internet
My 21inch Samsung monitor screen keep turning black
try another monitor to make sure that the problem is not as a result of there being no output from the system unit
Dec 22, 2008 | Dell Inspiron 531S (DDCWGA1_5) PC Desktop
Monitor Display Problem.
The first Polyview has a power supply problem (a short) and locks out the power until it is unplugged. You need to check the voltages inside the Monitor to determine which component/s are faulty. I hope you know electronics if not leave it to the repair shop because you have neither the skills or equipment to repair it. By the way I am not a monitor repair man but I do have 30 plus years in the electronics field.
The second monitor may have a broken wire in the cord that goes to your computer. Other internal components can cause the same simptoms your seeing. Good luck!
Mar 28, 2008 | Polyview V17E 17" LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
210 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
