Question about Dishwashers
My maytag dishwasher is not cleaning good anymore, things that just rinse off in the sink does not rinse off in the dishwasher
  • 464 Answers
Need model # around the opening of the tub. have you put any kind of cleaner in it recently?
Posted on Oct 04, 2009
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Filter needs cleaning. How do I get at the filter?
Dishwasher filters are important to catch food particles and other debris. The dishwasher cleans small portions of food from the dishes, cooking pans and silverware. These particles must go somewhere. The drainage system on the washer may clog if filters are not present. Most Maytag dishwasher models have two types of filters, "Coarse" and "Fine." You should clean the "Coarse" filter after two or three wash loads. The "Fine" filter can wait for a cleaning for about 300 loads or three months.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Sink sponge
  1. Empty the dishwasher. Remove all dishes including pots, pans and silverware.
  2. Pull the bottom rack out as far as possible. The filters are under the basket on the Maytag dishwashers. It may be convenient to lift the rack out. Typically, if you lift, the wheels leave the track.
  3. Remove the "Coarse" filter. This filter is a small, round knob in the middle of the "Fine" filter. A round knob is around the "Coarse" filter. Hold on to the handle and lift straight up.
  4. Knock the contents of the "Coarse" filter into the garbage can. Run the faucet to remove smaller particles. Wipe the dishwasher filter with the sink sponge if debris is stuck-on. Push back into the filter holder when complete.
  5. Take out the "Fine" filter. Turn the round knob that is around the "Coarse" filter counter-clockwise. Once the knob is loose, pull up. The "Fine" filter will come out of the dishwasher.
  6. Rinse the "Fine" filter with the hot water faucet. Scrub with the sink sponge to remove any stuck-on fragments. Replace the filter into the dishwasher. Push down and turn the knob clockwise to tighten.
Jan 09, 2011 | Dishwashers
I'm looking for a tear down manual for the Maytag MDB7100AWS dishwasher. There is soap residue everywhere and it barely cleans anymore. I think I just need to give everything a good clean. Can you help?...
Before you go tearing into your dishwaher start with the basics. That would be inspecting the drain outlet and drain hose from the sink connection point all the way back to the pump outlet connection. Most of the time what happens is there is debris in the air-gap at the sink or the garbage disposal connection port gets clogged. Then because the dishwasher does not drain peoperly you end up with dirty dishes at the end of the cycle. <br /> <br /> Here is the manual you were looking for: <br /> <br /> <a href="http://www.servicematters.com/maytag_library/docs/16021814.pdf">http://www.servicematters.com/maytag_library/docs/16021814.pdf</a><br /> <br /> Check your drain first. <br /> <br /> There are other things like a broken pump impeller / housing or clogged wash arms that can cause the same symptom of soapy film on the dishes post cycle. Also the screen on the top of the motor pump assy can be covered with a film of food particles. <br /> <br /> Thanks for choosing FixYa.<br /> <br /> Kelly
Aug 29, 2010 | Maytag MDB7100AWB Dishwasher
My dishwasher is not cleaning my dishes the inside of my dishwasher is thick with white residue
hello. I can help you. Make sure your dishwasher is empty. Then pour two cups of vinegar into the dishwasher. Next run the hot water into your kitchen sink until it is as hot as it gets and start your machine. Run it on the longest and hottest cycle you have..
This will clean your machine. Repeat the process with more vinegar if you need to.
Once your machine is clean, be sure to always run your sink water until it is hot before turning on the dishwasher and also rinse your dishes. good luck with it.
Sep 13, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Water is plenty hot,use rinse liquid
It is common thing the inside of a dishwasher is very nasty even though it cleans you dishes it is best to run a dishwasher cleaner through the unit ever other month I do my ones a mouth jet dry makes a good cleaner it is sold right beside the rinse aid
Apr 02, 2009 | Maytag MDB9600A Jetclean II Built-in...
Blinking Clean and Rinse lights on Maytag PD8460AWN
My Maytag PDB4600AWN quit working with a flashing CLEAN light and RINSE only button. I took off the bottom panel and took out the electrical diagram.
I ran the diag test, tried pulling power, and a series of other ideas just to see if the error always pointed to the same thing and it did. It's the motor pump. My Maytag is 10 years old. Not sure what yhe life span of such things are. My Mom had a Kenore dishwasher that ran 17 years. Don't think that happens anymore. I bought my Maytag laundry washer and dryer at the same time as my dishwasher and they have trouble now also. Guess those TV commercials were a little on the iffy side of truth. Hee heeeeeeeeeeeee. :)
I think I'll just buy a new dishwasher. The repair guys bill will be high enough that I may as well
Cheers
Feb 06, 2009 | Kenmore Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Maytag Dishwasher Will Not Rinse
You are probably not getting enough water into the machine. Replace water inlet valve (solenoid valve) and this should solve the problem.
Nov 13, 2008 | Maytag MDB7100AWB Dishwasher
Microscreens on Maytag Dishwasher
where to find the sand filter on a maytag dishwasher?
Nov 01, 2007 | Dishwashers
Dishwashers Logo
65 people viewed this question
Top Dishwashers Experts
