TV - PLX-4202B TV is plugged in and will not turn on there is no red or blue lite
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. The TV is not turning On because the power cable may be cut or loose. It can also be due to overheat issues inside the TV. The capacitors on the power board needs to be checked, if they are swollen or bulged. Also make sure that the connections coming to and from the power board are tight and firm.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 04, 2009
How do I repair a green tint on element tv model number PLX-4202B
Intermittent green tint is a source problem. Cable, satellite or HDMI cable.
Jan 02, 2015 | Televison & Video
There are only 5 wires from truck. Red, black,
aaaa more info your new plug should be marked as to what to connect to , DONT drive your self insane do one wire at a time and with a test light im guessing this is a rv flat spaded plug as i said start with one thing at a time turn on just running lights not headlights running lights that will put power in on wire only and that you want to connect to your plug running lites next shut off lights ,turn on a signal light signals will be a blinking light only on one wire.
Oct 08, 2014 | Cars & Trucks
T.V. wont come on although the red lite is on when plugged iun and the blue lite comes on when you hit the power button the screen does nothing it is a haier 32 inch LCD model L32F1120
Hi Judy
How old is your unit? but any way the problem of your unit is probably leaky capacitor. kindly check on the internet how leaky capacitor looks like.
Jan 19, 2014 | Televison & Video
Sharper image indoor/outdoor wireless speakers and transmitter has no audio.
First, determine if the TV device is putting out sound by plugging in a headphone into the audio out of the TV. If audio is there then the
transmitter and wireless speakers system may be at fault.
You can also plug in a CD player playing a disc into the transmitter to see if that source then transmits the audio.
Aug 21, 2012 | Audio Players & Recorders
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
WHEN I TURN ON THE POWER THE THE RED LITE COMES ON
We have a TV that does this after we have left it off but plugged in for awhile when we go on a trip. Just unplug the TV, wait a few seconds and plug it back in. If it's like ours, you'll find that resets it.
Nov 19, 2009 | Loewe ARC332 32" TV
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
TV Problem with shutting off by itself
Mine just did the same thing.  Except for it was green instead of blue.  The service manual states 8 flashes from the light stands for an overvoltage.  After reading the manual for a bit I realized the bottom row of 3 adjuster screws from behind the speaker grill adjust the output for the red, green, and blue colors.  BEFORE OPENING ANY TV OR MONITOR PLEASE KNOW THAT THE VOLTAGE INSIDE CAN KILL YOU EVEN IF UN-PLUGGED so please be careful and only adjust what is mentioned here.  I un-plugged the tv, removed the grill and the board covering the internals, and carefully turned the 3 adjustment screws all the way down.  I then waited about 10 minutes (don't know if this made a difference).  I turned on the tv, turned the channel to an auxilary input (for a black screen), and slowly raised each of the 3 bottom screws one by one up clockwise until i could see a faint green, blue, or red line (depending on the screw), and then turned each one back a hair until the screen was black again.  Only adjust one at a time, the order for colors are blue, green, then red from the left.  I hope this fixes your problems.  Be careful when working inside a tv,  I suggest not using a screw driver to adjust the screws due to the possibility of it slipping and someone getting hurt.
Sep 16, 2007 | Sony KP-51WS500 51" Rear Projection...
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
