Question about HP LaserJet 1200 Printer
My CP1215 will not print multiple copies. No matter how many copies I request, I always get just one. This printer is less than two months old.
  • 3 Answers
SOURCE: hp business inkjet 2800
Sounds like your driver is sending A4 size documents, and you've got Letter in the drawer. When you do that, it runs out of room on the Letter-size page, since A4 is a tad longer, and has to continue onto a second page. Margins being what they are, the second page is usually blank.
Hope that helps.
Posted on Jul 31, 2008
freetek
  • 5568 Answers
SOURCE: My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Posted on Sep 23, 2008
alvinbga
  • 130 Answers
SOURCE: hp LaserJet 1320 will not print multiple copies
Try another program, and select multiple copies. If the printer print multiple copies from the other program its the software. If it does the same thing it is the printer. You can also test with anoter computer.
Posted on Nov 20, 2008
gwbm
  • 353 Answers
SOURCE: My Epson C60 won't print multiple copies
I cannot think of a sensible reason why a faulty ink cartridge should stop the computer printing more than one copy (your post does seem to confuse "page" with "copy" though). To eliminate the cartridge as the source of the problem, you should install another one (a cheap clone on e-bay); if it now works, then yes, it was the cartridge causing the problem. If you still get the same problem, no, it isn't the cartridge. If it is the latter, I suggest you uninstall the printer, turn the printer off, reboot the computer, then re-install the printer, but do not turn it on until told to. If this works, the mystery remains why changing a cartridge should cause a printer driver hiccup! If it doesn't work, repost back with a new post and we'll scratch our heads a bit more!
Posted on Mar 26, 2009
SOURCE: My hp 1320 prints multiple copies instead of one copy
Go to "printers and faxes."
Right click on your printer and select "Printing preferences."
Select "Advanced" tab
Double click "paper output"
If "Copy count=2" then change to 1 and apply
IF IT ALREADY IS SET TO 1 THEN:
Set "copy count=2" then APPLY
Repeat the above and now set "copy count=1"
The process of setting and resetting the copy count fixed my issues.
Posted on Mar 01, 2010
HP CP1215 Printing is blurred
should of included a pic of print.
Blurred prints are usually fuser related.
Nov 15, 2016 | HP LaserJet CP1215 Color Printer
I own a CP1215 which is barely a month old. It worked fine until yesterday. Suddenly, each time I attempt to print, it gets stuck as it comes out. I followed a tip I found online and close the back tray...
This might not be a solution, but rather something to get your job done if nothing else (if it works):
Try using the "manual feed" tray instead of the paper tray. Depending on where the jam is occurring in the machine, it could bypass that spot and print fine.
Best of luck!
--JK
Mar 03, 2011 | HP LaserJet CP1215 Color Printer
Printer prints blank sheets
I would suggest resetting the printer options to Default first. If that doesn't do it then reinstalll the complete printer software and be sure to deleted all the old software. To delete files completely download <AppCleaner> it's free and is fantastic. Your last resort is to then call Epson Tech Support.
Apr 04, 2009 | Epson Stylus CX9400 Photo Printer
Printing multiple copies
when you open the driver of the printer there is a information how many copies do you want.it shows 1
Dec 18, 2008 | Office Equipment & Supplies
Multiple copies
Look for a small "Collate" box and make sure it is checked. That way it will print each set in order.
Sep 26, 2008 | HP DeskJet 5550 InkJet Printer
I-class cutting issues
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Label printers are always finicky. I have strtix printers where I work and they give off wacky errors too.
Sep 19, 2008 | Datamax DMX-I-4212 Label Printer
(=Plug and Pray)
Sep 16, 2008 | HP LaserJet 1320 Printer
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
HP LaserJet 1200 Printer Logo
129 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
