Question about Acer Aspire One PC Notebook
Acer one does not come on power light alone is on
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 166 Answers
Try take of the battery and try to power up if do the same try outher power cord /power supply if you have the same result maibe you have a bad motherboard if that check garanty thanks
Posted on Oct 10, 2009
Why does my acer b243hl black out intermittently
Sounds like your power supply or board inside the monitor is bad....may need to be replaced.What kind of power supply is it...just a cord or box going to monitor?
Sep 04, 2014 | Acer Computers & Internet
Battery Light flashes twice and does not boot up
Are you plugged in at all? Try with plug plugged in. I think your battery is dead.
Aug 05, 2010 | Acer Computers & Internet
Acer Aspire 5920 will not power on at all. The
Just to make sure:
1. With battery alone in notebook, and no power cable, do you get power?
2. With the battery taken out, and power cable plugged in, you do get power?
IF YES to the above two questions
... and u can get power using the power cable but not using the battery, then your battery is dead and u need a new one.
Mar 16, 2010 | Acer Aspire 5920-6727 Notebook
Aspire One notebook won't power up. If I hold down the power button with the battery in, I can get the indicator light to blink red, but no start up. Have tried to remove battery and left it alone for...
Try to power up with the battery charger cord plugged in and attached. Then you can use AC power while the battery charges. Also check your power options. When the battery light turns green it is done charging. Then try using the battery alone again.
Feb 28, 2010 | Acer Aspire One PC Notebook
Acer Aspire 5920 won't turn on, the charger lights up, (bright green) until you plug it into the back of the laptop, then the light goes dim and flashes.still no power to the laptop,not even the fan.
Your power supply or regulator in you laptop has gone south. sorry no quick fix for this one. It needs repaired and would include tracking down soldered connections.
sorry to tell you this.
clb199@yahoo.com
pls rate me 4 stars
Nov 27, 2009 | Acer Aspire 5920-6727 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
This is a pink acer aoa150-1690
Check for the AC adapter lights.
If on.
Remove battery and try with AC adapter alone,
Remove Adapter and try with battery alone,.
Remove power cable and battery and press power button for 30 seconds.
Place battery and Ac adapter back in its place,
Check with a different power chord first and see whether it works fine.
If this does not help then the issue is with the other internal components.
You may want to remove the hard drive, memory and the Optical drive with the battery and the AC adapter out.
Even if this does not help then the issue could be with the main board.
Sep 09, 2009 | Acer AOA150-1690 Aspire Notebook
Acer laptop travemate wont even make any noise or boot up... why?
My initial thought would be that your battery will no longer hold a charge or that your power supply has gone bad. Try taking the battery out and booting the computer with JUST the charger. Any change? How about booting from the battery alone? Have you had any spills on or near it in the last 6 months? If it turns out to be a battery, you can buy them online for around $70. There seems to be an abundance of parts for this model acer. It definitely sounds power related though. If its not the battery or the power supply, my last guess would be the motherboard. Good luck and let me know if things change as your are testing it.
Feb 21, 2009 | Acer TravelMate 2300 Notebook
Acer Aspire One  PC Notebook Logo
96 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
