Question about Maytag UMV1152CAS 1000 Watts Microwave Oven
Is the model umv1152ca a non-vented, vertical, or horizontal duct
  • Maytag Master
  • 9,047 Answers
You can download the owner's manual and installation guide here.
They should answer those questions.
Posted on Oct 06, 2009
Kenmore microwave model #79080353310 vent
That's probably normal. The flapper valves aren't meant to be perfectly airtight.
Your manual page is here. It has both the installation instructions and the owner's manual.
For more free DIY and other help & advice, feel free to contact me directly.
Please include FULL model number*, FCC ID number*, + detailed symptom information.
* (on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 26, 2017 | Kenmore Microwave Ovens
I have a Maytag microwave UMV1152cas. I recently replaced the magnetron because it was not cooking food. I began putting it back together and have it all back together except for a plastic piece.
HI,
Maybe this will help. Here is a link to an explode view of your Microwave. There are other exploded views on the right-hand side of the page.
http://www.appliancepartspros.com/02-body-cavity-parts-for-maytag-umv1152cas.html
Jul 22, 2015 | Maytag Microwave Ovens
How to vent exhaust outside
bea12bfe-3a65-4764-8544-5bc63391c2dc.jpg9dbdeaa6-0b81-4926-ab21-2206dc8f6420.jpg6bfcce66-f35e-4950-b5c4-5ba9eff2c34c.jpgI usually choose an outside wall if possible to vent outside. You can buy a rear vent that is superior to a dryer vent. When this isn't possible you need a rectangular duct going up through your cabinet and up through your ceiling. hopefully you have an attic or you have to switch to a 5 inch tube going sideways (above your cabinets (if there is space) to the outside wall. If it goes into an attic you have to cut through the shingles to a vent made for bathroom and or hood vents. The motor and blower assembly inside your microwave is designed to turn to be front facing, rear facing or vertical facing. Just unscrew or break out the side that you need to vent through.
Oct 21, 2013 | GE Spacemaker JVM1540 Microwave Oven
Can the lg lmv2083st microwave be vented to an outside vent? not clear from the installation manual.
On page 8 of the installation manual I found, it shows that the oven can be vented to the outside. You can view it at this link:
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0707162.pdf
If the link does not work, you can go to managemyhome.com and type in your model number under the "Manuals" link.
In the manual it describes three methods of venting: Room, Roof, and Wall. It also gives guidance on how to properly install the duct work.
If you have questions, please let me know. I hope this helps you.
Aug 21, 2009 | LG LMV2083SW Microwave Oven
My Micro vents into the kitchen instead of venting up the exhaust vent. What could be wrong
The fans on an over the stove microwave can be rotated up to 180 degrees depending on how the installer intends to vent the hood. Your fan is pointed forward and venting into the kitchen through a charcoal filter. If you want to vent through the ducting and out of the kitchen, you'll have to drop the microwave down off of the mounting bracket and rotate the fans in the back, pointing the dicsharge upward for a vertical vent, or 180 degrees, if it discharges out the back (wall vent). In both cases, an adapter is necessary, and can be obtained at any hardware store.
Best regards, --W/D--
Aug 08, 2009 | Tappan TMT104E1 Microwave Oven
VENT NOT SUCKING
I would suggest checking the filters, checking the duct work (including the outdoor vent) and if that doesn't turn up the problem, the hood vent exhaust fan blade assembly may have come loose on the shaft.
You can download GE owner's manuals and installation instructions here to help you verify the filter status and duct work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1790 Microwave GE-Draws air from bottom and top vents
1. You have to have exhaust pipe to connect m/w vent and this pipe has to be free from obstruction.
2. If it already connected and good, but air come from vent bar over door, then blow motor on top of the m/w was installed in wrong position ( motor has 2 -3 position depends which way air coming out up, back or front).
3. In this case you have to remove m/w from installation and change motor position.
Dec 10, 2008 | GE JVM1490 Convection/Microwave Oven
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
You can download the owner's manual and installation manual here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
Maytag UMV1152CAS 1000 Watts Microwave Oven Logo
101 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
