Question about Nokia 6030 Cellular Phone
  • mahede Dec 26, 2007
    hi i am work in saudia in a mobile shop. more time i get a problem in sim card puk. how can i know this sim puk can you tell me
    thank you
  • 1,017 Answers
Ajay gupta first problem you might have too many connections on your pc for the same Application, ie. PC Suite.
Right click on MY COMPUTER,
They will be restored when you restart.
Posted on Jan 01, 2008
  • Raysagem
    Raysagem Jan 01, 2008
    mahede Second problem. The SIM card is provided with a PIN (Personal Identification Number) and a PUK (Personal Unblocking KEY) this key (PUK) is also available at your service providers.
    If you enter the wrong PIN too many times, you need to Unblock the phone with the PUK.
U must hav ur mpbie prt
Posted on Dec 22, 2007
I just reset my dell computer back to factory setting. How do I now reset up for internet connection. My provider is verizon and I am using internet explorer
You want to reset your internet connection???
If yes then follow the given steps....
Step 1
Turn the modem so that the back of it is facing you. Locate the power supply cord connected to the back of the device.
Step 2
Gently unplug the power supply cord and leave it unplugged for about 10 seconds. If you also have a router connected to the modem, disconnect the power cord of the router as well.
Step 3
After about 10 seconds reconnect the DSL modem power cord. Wait for the status lights on the front of the unit to come on. They may blink at first before turning solid green, or they may first illuminate as orange, then turn green, depending on the modem model. The "Internet" and "Incoming" lights may continue to flicker, this is normal operation for modems.
Step 4
After the modem is reset, reconnect the router power supply if you have a router. Wait a few minutes before resuming normal Internet use.
If you need any kind of technical assistance you can contact support cell
Jan 19, 2013 | Computers & Internet
My gateway computer power light blinks and moniter says no signal.turn it off held then power button on for 30 seconds.then turned it back on.same as before.
I don't think this has anything to do with the monitor since it is showing "no signal". this is an indication that the monitor is working.
Problem is from the connection between the computer and the monitor or from the computer itself.
Check the VGA cable and make sure it is firmly fixed into the computer and monitor.
Open the computer case, disconnect the keyboard, mouse, and every other thing apart from the VGA cord, then try again.
If there is still no signal, turn computer off again, remove it's power cord, then remove the system Ram, clean it and fix it back in. Then make sure the VGA card is well fixed into the mother board. After that, connect only he VGA cord and try again.
If non of the above seems to work, connect the computer to another monitor, and connect the monitor to another computer in other to confirm which is having a fault so that we can focus on it.
Keep me posted.
Good luck.
Jul 11, 2011 | Smart Modular SV3170A
Cant find driver for lg flatron 295lm monitor it keeps disconecting from my computer
OK, a monitor usually does not need any drivers to be installed. Hence, if the screen keeps disconnecting you might want to have a look at the connecting point between the monitor and your computer and the power connection.
Try different VGA cables and power cables, let me know if the problem persists, so we can try something else.
Kind regards
Sep 03, 2010 | Microsoft Windows Vista Ultimate Edition
Hp deskjet 3650 printer works very slowly with win 7
tion one: Check the power supply Follow these steps to check the power supply to make sure that it is functioning correctly.
  1. Turn the product so that you can access the rear side.
  2. Unplug the power cord from the back of the product. Figure 1: Unplug the power cord from the back of the product
  3. Remove any devices between the product and the power outlet, such as surge suppressors or power strips.
  4. Plug the power cord directly into a wall outlet.
  5. Print and time a self-test again.
  • If the test page prints in 30 seconds or less , the problem relates to the power supply. Replace devices between the product and the power outlet, or leave the product connected directly to the wall outlet.
  • If the test page takes significantly longer than 30 seconds to print, continue to the next solution in this document.
Solution two: Check the USB connection
  1. Disconnect the USB cable from the back of the HP product. Figure 2: Disconnect the USB cable from the back of the HP product
  2. Disconnect the USB cable from the back of the computer.
  3. Wait five seconds.
  4. Reconnect the USB cable to the back of the product and the computer, according to the following guidelines: The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Connect the small end of the USB cable to the back of the product Connect the other end of the USB cable to the computer
  5. After you make sure that the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
    • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
    • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high-quality. Otherwise, HP recommends using a USB cable that is less than 2 m (6 feet, 6 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
    • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the problem.
    • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
    • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
  6. After checking the USB connection, print and time a self-test page again.
  • If the test page prints in 30 seconds or less , the problem relates to the USB connection. Replace the USB cable or modify the connection to meet the preceding criteria.
Solution three: Check cartridge compatibility Incompatible cartridges can cause the slow printing problem. To check the cartridge compatibility for your product, go to HP SureSupply . To identify your cartridge in a language other than English, click the language link near the globe icon (c01906983.gif ) in the upper right corner of your browser. Examine the cartridges in your HP product, and then follow these steps to check which cartridges are compatible with your product. The number on the cartridge label must match the numbers listed on HP SureSupply.
  • If the cartridges are not compatible with your HP product , replace the cartridges. You can order replacement cartridges directly from HP SureSupply.
  • If the cartridges are compatible with your HP product , continue to the next solution in this document.
Solution four: Perform a reset A reset drains the power from the product and returns it to the same settings after restarting.
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product. Figure 3:
  3. Disconnect the data cable (USB or Ethernet, depending on how your product is set up) from the back of the product. USB cable Ethernet cable
  4. Unplug the power cord from the wall outlet. Figure 4: Unplug the power cord from the wall outlet
  5. Wait about 30 seconds.
  6. Reconnect the power cord to the product and wall outlet, and then turn on the product.
  7. Print and time a self-test again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Mar 31, 2010 | HP DeskJet 3650 InkJet Printer
DI 624 Was working ,disconected , reconnected work no more.
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
Click Here for more information about router and networks.
Jan 10, 2010 | D-Link Computers & Internet
Ipod nano 4gb will not connect to my pc
I found the solution to this problem:
To get your iPod Nano 3rd Generation (4GB video) to be recognized by your computer, you will need to manually get it into "Disk Mode" here's how:
  1. Verify that it has a full charge, if not, you need to either charge the iPod before continuing or connect it to a high-powered USB port, or simply connect it to the Power Adapter that plugs into an electrical outlet. (just not connected to your computer)
  2. Toggle the Hold switch on and off once. (Set it to Hold, and then turn it off again. Just slide back and forth.)
  3. Press and hold the Menu and Select (center) buttons at the same time for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select (center) buttons and immediately press and hold the Select (center) and the Play/Pause buttons until the ‘Disk Mode’ screen appears.
  5. Disconnect your iPod from the power adapter and connect it to your computer;
  6. Now the screen on the iPod will change and say "Do not disconnect" and should be recognized by your computer.
I hope this helps you; I had a hard time finding a solution and thought I'd share the wealth once my stress was relieved.
Jul 11, 2009 | Apple iPod nano
When i turn my ps3 on,red light goes green then red right away
Try disconnecting your PS3 and then for 10 seconds if that doesn't work, disconnect all jackets meaning all usb connection ports connected in it. Remove them, then turn on your ps3 see what happens (without using the controller), then disconnect the ps3 cord that connects to your extension cord or jacket and plug it back in. Try it again. Then again with the controller could try. Try disconnecting other ports such as other stuff like as listed, Irons,Fans, etc.           !!!!!!DON'T USE TOO MUCH POWER!!!!
The Same thing happened to me on my Wii though.
If nothing works call Customer Support (SONY)
May 30, 2009 | Sony PlayStation 3 40GB System
Hp psc2355v print cartridge is stalled then error carriage jam. I have cleaned the excess ink the metal carriage ? but when i clear the jam it does it again and stops at the left
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
Thanks for using FixYa.
Jan 28, 2009 | HP PSC 2355v All-In-One InkJet Printer
Older whrilpool dryer
make sure the green wire is connected like in the picture. this connects directly to the neutral, if it is disconnected when you connect a 3 wire cord then this problem you are having will happen.
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
It shuts off when i connect to the usb
MyMusix's PD-6030:
If you have a Windows-based computer,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If that fails,
Check the battery polarity. (+ and - must be in correct psoition)
Set the hold button to the unlock position.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format
If that fails,
go to to see if the latest software update will correct the problem
-Tha Mp3 Doctor
Dec 16, 2007 | MyMusix PD-6030 MP3 Player
Nokia 6030 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
