Philips 42PF7320A 42 in. HDTV Plasma Television
Problem for Philips 42PF7320A 42 in. HDTV Plasma Television
Tv turns on but pictur has lines through it?
By ahrenorlando on Oct 04, 2009
tv turns on but picture has lines through it? is there a card inside that can be replaced?
Solution #1
posted on Oct 29, 2009
Somewhat Helpful)
Relict
Rank: Master
Rating: 88%, 3 votes
Your TV could be picking up electrical discharge from an old appliance. Try removing the secondary ground by installing a 3 prong to 2 prong adapter, or just pulling it out with pliers. Common problem with HD sets.
Was this helpful?
Yes
No
Solution #2
posted on Oct 24, 2009
Somewhat Helpful)
Cruxis
Rank: Guru
Rating: 89%, 24 votes
If the lines are verticle,it could be a bad control board/data ribbon that connects to pdp panel. if they are horizontal lines,it could be the y boards (main for power, buffer upper and lower control half of the panel each) if not,replace swollen capacitors on the power board.
Comments:
Oct 24, 2009
- If the lines are verticle,it could be a bad control board/data ribbon that connects to pdp panel. if they are horizontal lines,it could be the y boards (main for power, buffer upper and lower control half of the panel each) if not,replace swollen capacitors on the power board.
Was this helpful?
Yes
No
Popular Solutions for Philips 42PF7320A 42 in. HDTV
Questions and Unsolved Problems for Philips 42PF7320A 42 in. HDTV
Do you recommend Philips 42PF7320A 42 in. HDTV Plasma Television?
Answer
Answer
how do I connect a philips 37fd9954 plasma hd monitor to a digital cable box
Answer
sounds like its turning on an off by itself . came home today the tv was clicking no one home all... (More)
Answer
Hi I have a philips 42" flat screen and the screen has gone blank and red light is flashing
Answer
turn tv on and turns right back off with a red light flashing and cannot get to start without... (More)
Answer
has raster momentarily then power supply shuts down.
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in , PA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
