Question about Garden
Lawn Tractor will not start.
I have a Cub Cadet Model 1515 lawn tractor. It will not start. Itried to jump - nothing; no noise or clicking. full of gas. What do I try next?
  • Daren Ingold
    Daren Ingold May 11, 2010
    1) Load-Test battery (most autoparts stores offer this for free). 2) Check for voltage at the small trigger-wire on the starter solenoid with key in the START position. If voltage good, replace solenoid. If voltage drop or not present, replace ignition key switch. Hope this helps.
  • 472 Answers
Re place the fuse its a small 10 to 20 amp is by the solenid wer the batt cabel hooks up frome the batt
Posted on Oct 04, 2009
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
I need to see a diagram on how to put a deck belt on a 1515 cub cadet lawn tractor
This YOU TUBE link will hopefully help you. www.youtube.com/watch?v=iwjI4i-dLFk
Apr 18, 2014 | Garden
How to check the charging system of cub cadet 1515
start engine put volt meter across batt terminals should min 12v max 13.8v
Aug 28, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet 1515 won't start
I just had the same problem. I installed a new spark plug, sprayed some starting fluid in the engine and it started right up. I mowed my entire yard, and my neighbors yard with no problem?? I'll post more next mow and let you know if it has fixed the problem!!
Apr 29, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I HAVE A CUB CADET LT1050 LAWN TRACTOR AND WHEN I TURN THE KEY I GET ONE SINGLE CLICK. THE STARTER DOESN'T ENGAGE
Hi camy wils815...
Sounds like you have a faulty solinoid.
Make sure your battery has a full charge, the by-pass the starter solinoid on the engine.
To do this ground one big wire connection to one of the small wire connectors (with the wires still hooked up) and if it starts, then replace the solinoid...if it does nothing, replace the solinoid.
Please take time to rate me
Jul 30, 2011 | Cub Cadet Street Sign- tractor lawn riding...
The pto on my cub cadet 1515 cuts off. It will
Mine does the same thing. I've found that normally this is a heat-related problem and by removing all the clippings from the deck the blades will re-engage just fine until (unless) the clippings mount up again. Hope this helps; I make sure the deck is clean top and bottom before I mow.
Sep 01, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do I change the drive belt on a 1500 Series Cub Cadet Lawn Tractor
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Jun 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
199 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
