How to remove screen cover from quasar sr4500ek for cleaning - dust has accumulated between the plastic screen cover and the actual tv screen!
  • mobondarosa Oct 04, 2009
    how to remove the plastic protective screen from a Quasar SR4500EK TV for cleaning purposes - dust has accumulated between the plastic protective screen and the actual TV screen! I have looked at it very closely and do not see an easlily apparent way to do so. Is the groved plastic covering acually part of the TV screen and is it even supposed to be removed?
  • 657 Answers
You may purchase the service manual from here, which will give you the information
http://www.nesselectronics.com/index.php
Posted on Oct 04, 2009
  • 8,197 Answers
To remave screen plastic you need to get a service manual from this site.
http://www.pacparts.com/model.cfm?mfg=QUASAR&model_id=SR4500EK&action=list_part&CFID=3598116&CFTOKEN=3240994&back=0&mode=auto
good luck
I saw some dust accumulated underneath of display of my samsung innov8 mobile phone.Could you help me,how i can remove that.
Using a small pocket knife blade or some other thin edged tool, start at one of the bottom sides, near the screen cover's hinge, and carefully pry off the cover, loosening as you go. The glue that holds the screen cover on is a tacky substance and will re-stick after you've cleaned the screen. Slowly and carefully slide the knife along the edge of the flexible plastic, and lift it up as it pulls free of the adhesive.
You can leave the bottom of the screen attached while you wipe with a very soft cleaning cloth or compressed air. Remove the dust off of the screen and then simply press the screen cover back down and run your thumbs around the edges to reseal it.
That's all it takes, and you don't need to buy any fancy tools.
May 01, 2011 | Samsung SGH-i8510 INNOV8 Cell Phone
I have a Hitachi projection color tv and I cannot get the color adjusted good especially the red. Can you help me?
U know how to solders?Ur convergence it dead,need it replaced parts,by buy convergence kit.Tries Tv repair World.com,Tvrepairkits.com.
Dec 20, 2009 | Hitachi 43UWX10B 43" Rear Projection...
My color is off on my whole tv i have a 52''projection toshiba cinema series the old big style and was wondering how to adjust the colors so they match up
Sounds like what was wrong with mine! Take the remote and hit menu, then scroll to the Video Adjust button, then adjust the "convergence" or the color tone, brightness, contrast etc. My repair man did this and it helped get the picture much more life-like. He said over time they get out of line and just need a few adjustments. He just charged the $50 house call. Good luck, hope you can fix it.
Dec 11, 2009 | Toshiba 50H81 50" Rear Projection...
I have a philips HD rear projection TV 60 in. inside there are six adjustment knobs. Three are color the other three are for brightness contrast and hue. Which is which Left to right
If yours is a rear projection TV the adjustment knobs on the focus block inside are screen (red, green, blue) and focus (red, green, blue). The ones you are referring to as color are the screen controls and they adjust the intensity of the color from each tube. The other set adjust the focus of each color. They are also not intended to be adjusted by the user. Unless major components have been changed these controls should not need adjustment. That is why they are inside the TV.
Dec 05, 2009 | Philips 60PP9352 60" Rear Projection...
TV appears blurry, and when using the remote to solve remote and buttons on tv are not allowing to re adjust colors for a clear pictue
Read Each Step Completely - Make Sure 3 Color Guns Are Off And Cool -
1. Remove Rear Dust Cover 2. Remove the Front Speaker Cover May be Held In By Plastic Pins and or Anchors on the Bottom Note" - Remove The Plastic Cover Just Above Speaker Cover Maybe 2 Piece. Remove The Screws Holding Top Of Speaker Cover. Then Pull Toward You the Bottom Maybe Anchored So Lift Up. 4.Once Speaker Cover Removed, May Have Screws Just Below Center Plastic Cover Remove Them, Now Remove Center Cover Between Speakers -NOTE" Do Not Touch, Move Any Color Convergence KNOBS" - Lift Front Screen UP - Towards Roof - It Has 3 Flex Grab Anchors On Top And 2 Pins One On Each Side Of TV Frame. - NOTE" Lay Screen On Floor It Is Plexi Glass So It Will Brake If Bent Or Drop Hammer On. NOTE"- May Have To Remove plastic Cover Frame positioned Around Front Screen And Then Remove Screws. 5. I Use Windex Glass Cleaner And Either Cotton Balls Or White Tube Sock On Color Gun Lens Covers And Clean Mirror Like The One In Bath Room. 6. Take White Sheet Or Bead Spread And Anchor On top Of TV With Weights, Stretch Around Each Side Of TV Use Chairs To Anchor On Each Side Of TV. Place Dust Cover Or Heavy Card Board Where Plexi Glass Was Positioned. 7. Turn On TV - go To Rear and Now You Can Adjust Colors Brightness And Low Light - High Light - Horizontal - Ect....While Looking at Picture. 8. Install In REVERSE - Order Just Wipe Color Guns Lens Last. Note" - If you have Wet/Dry Vac or Fan Or Blow Dryer Take A 2 - to - 3 Inch Paint Brush And While Brushing Circuit Boards Any Dust For That Matter Blow Dust Off And Out Even Brush Speaker Cover"...ECT...Do This Before Any Cleaning 9. Just A Thought If You Ever Want to Change Color Gun Cooling Oil - Wrap All Circuit Boards With plastic Bags And then I use Bath Towol And Paper Towols To Catch As Much Spill As I Can And Then Spray With Windex To Make Dry While Blowing Air Onto Spill - Also I have Found Clear Mineral Oil Like Johnson Baby Oil To Work As Well If Not Better Then Glycol Oil. I Get For $2.50 For 20 Oz Bottle.
Nov 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I install/adjust color lamps on a Hitachi 51UWX20B rear projection tv
Nov 22, 2009 | Hitachi Televison & Video
Every thing on the tv is mostly blue
Nov 20, 2009 | Hitachi 51G500 51" Rear Projection...
Hitachi 51UWX20B spider web like lines help
I know my response is a while after you asked, but to clean the inside of the tv case is pretty simple.
Remove the bottom speaker cover...on this model you just pull it off. There is no clips or screws.
Once the speaker cover is off you will see the bottom of the screen, there is 4-5 screws on the bottom on each side....I think 4 in the gray plastic and 1 in a black metal strap. With all of those screws out pull out SLIGHTLY on the screen and push up. The top is held in with a down force clamp and you are just popping it out of that....It will pop back in once you are done.
Now clean the back side of the screen, the mirror and CAREFULLY dust off the lenses. I myself did not want to use any cleaners (to avoid streaking) so I used a new microfiber dusting cloth. My picture became brighter and the "crack" that I thought I had was just a dust web....
Hope this helps and good luck
N8
Mar 06, 2009 | Hitachi 51UWX20B 51" Rear Projection...
Cleaning cobwebs from philips rear projection tv model 51PW9363/1
I had the exact same problem and the fix is easy to do. Unplug the TV first of all and wheel it out so you can easily get to all of the rear screws.
  1. Remove the screws from the ventilated back panel (the piece of wood with a bunch of holes in it surrounding the AV connection panel.
  2. Remove the wood panel you just unscrewed.
  3. Remove all screws from the upper plastic case on the back.
  4. Remove the back plastic case carefully. This is a little tricky due to two metal pins that it hangs on. Lift it upwards and you should be able to free it from these pins
  5. At this point you should be able to see the entire workings of the TV, and consequently the massive amount of dust that has accumulated.
  6. Carefully take a vacuum and remove all the cobwebs, taking care not to bump the mirror or the lenses.
  7. First, I used some compressed air to clean off the lenses and then used a clean microfiber towel to remove all the dust from the lenses, the mirror, and the screen on the inside. Make sure the part you are wiping the mirror and lenses off with is free from any dust or dirt or you will risk scratching them.
  8. Reverse the dissasembly process to put the case back together.
  9. I went through the convergance settings at this point and found that they were all out of calibration and as such recalibrated them. Use the mulitpoint calibration for best results.
  10. Enjoy a much cleaner brighter TV!
Jan 25, 2009 | Philips 51PW9363 51" Rear Projection...
Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
Wow, You are asking for a complete disasemmbly. If this is necessary, you have to remove any screws you can find that are connected to the front panel. Usually they are in the top of the set ( you'll find them after removing the mirror panel and mirror ). I wouldn't remove any tubes as the tube convergence would have to be all reset and that would require a cross hair generator. I do hope this has helped in some way, but all I can do is send you my best wishes as I certainaly don't suggest disassembly if there is any other way. Good luck
Ed
NC Electronic
Mills, Wyoming
Nov 24, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
