Question about Fuji FinePix S5000 Digital Camera
Fuji S 5000
Camera was dropped. the battery cover no longer closes because one or more of the plastic pieces broke on eithr the lid or the battery holder.
Is this battery unit: battry compartment and lid--replaceable? If you cannot answer immediately, please email to: finewine@ptd.net
Thankyou. Hugh Sherry
SOURCE: Battery compartment cover
Hi how u going? I just brought a new cover for AUD24.01 which includes postage n tax from Fuji here in Australia.
Fujifilm Australia Ltd 114 Old Pittwater Rd Brookvale NSW 2100 Australia Ph (612) 9466 2600 www.fujifilm.com.au
Freecall 1800 226 355
All the best
Paul
Posted on Nov 19, 2007
cammedic
  • 667 Answers
SOURCE: battery cover
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
Posted on Jan 23, 2008
cammedic
  • 667 Answers
SOURCE: Replace Battery Cover
Okay,
Separating the front and rear covers of the camera is not that difficult. You'll need a good small cross point screwdriver. I do not have a 2600 in front of me, but the 2650 is similar. Remove all the screws around the sides of the camera. The top sections are snapped together. work along the back edge to undo the snap tabs. I do not remember if there is a ribbon cable attached so go easy when you remove the back half.
My chat is not working yet, so if you want to go this far, let me know
Posted on Jan 24, 2008
SOURCE: Fuji S3100 Broken Battery Latch
There are two potential solutions that I know of, but only if the broken tabs are on the door and not the camera body. Double check which tabs are damaged.
The first involves getting a new door somewhere (good luck with that... Fuji doesn't seem to sell the parts to civilian consumers... you might try getting the part from an old non-functional one on ebay or something). The trick to removing the battery door is to push the door's hinge pin (with the door open) towards the back (LCD side) of the camera from the opposite (front) side. There is very little clearance. I have successfully used a paint can opener to do this on a S3100. You can brace the back side of the opener against the lip of the camera body and push the pin out. Once it is as far out as possible, use needle nose plier or tweezers to grip the now exposed end of the pin and pull it all the way out. Then put the new door in place and re-insert the pin... there may be a little resistance.
The other was recommended to me by a camera repair man, but I have not tried. I would probably have let him do the work, as it seems a little risky, but possible. It basically involves getting a small washer that will fit under the two latching tabs near one another on the body. After figuring out the correct position for the washer to be attached to the door that it will just slide under the tabs and secure the door, you must use a small countersunk screw through the central hole in the washer to attach it to the door. You might have to remove the rim of the door in that area with an exacto knife or something similar so the washer will fit well. Like I said, I would have probably let him do the work, but it sounds like it would work.
Another idea that just occurred to me is a little more work intensive but would probably work would be to sink a (coarse thread) screw through the door all the way into the plastic of the body (maybe 2 or 3 in different places), which could simply be unscrewed any time you wanted to change the batteries with relatively little trouble.
Good luck! =)
Posted on Feb 12, 2008
SOURCE: How do I replace the battery cover
There is a little spring latch on the larger of the 2 metal components, (the one mounted to the body) on the cover. Raise this gently and the cover just slips off. A replacement can be bought from Camerashop.in for about $10. Fuji wanted £97 to do this!
Posted on Jan 16, 2009
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Battery cover clips broken
I had the same problem with mine, sent mine to Fuji for repair.
Unfortunately they no longer have parts for this model, 8-(. I simply had to resort to using tape to keep the cover closed.
Jan 25, 2014 | Fuji FinePix S5500 Digital Camera
The orange plastic clip that holds in the battery broke.
use some tape, or put a piece of something on top of the battery, when you close the battery door and latch it, it should hold the battery in place. That orange clip just holds the battery low enough that it comes in contact with the terminals at the bottom of the compartment.
Hope this helps
Jer
Jan 16, 2010 | Pentax Optio T20 Digital Camera
Hello i have the hp r937 and i had dropped it and the door to the battery will not close now i think a part on the actual camera broke of not on the door is there a way to fix this?
Did you find someone that fix it?. I dropped mine today and there was a small plastic piece that helps to close the door, it broke, now the door won't close.
Nov 22, 2009 | HP Photosmart R937 Digital Camera
Battery Cover Broken
You will need to replace the battery cover assembly and contact Kodak at 1-800-431-7278 during normal business hours (Monday - Friday from 8 a.m. - 5 p.m. EST), and select option 3.
Jun 16, 2008 | Kodak EasyShare C340 Digital Camera
Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Mar 28, 2008 | Fuji FinePix F40fd Digital Camera
Battery cover for cds6300
the molded plastic clips ,when cover is closed and pushed in to lock are broken from camera body both pieces. How and where can it be repair.
Oct 21, 2007 | RCA CDS6300 Digital Camera
Fuji S3500 Finepix just stopped working
If you have had it less than a year or even a little over- Fuji may come up with a modestly priced or even FREE replacement,if over and , before you send it to a repairer or contact the Fuji Tech Support team try one more thing. Take the batteries out and with the end of pencil, eraser - give the contacts at bottom the battery chamber a polish. Now take a look at the lid of the chamber if it has a continuous piece of metal inside so as to cover the battery ends put a piece of foil across them if two batteries ,or arrange 2 pieces of foil to replicate the correct alignment if 4 batteries Then close the lid . See what happens - it may simply be a battery contact thing.
Jun 06, 2007 | Fuji FinePix S3100 Digital Camera
Fuji 4700 zoom
there is some chance that it's not getting power for the shutter release. Either becuase of some internal error on the switch, the circuit isn't closed, or that the batteries aren't performing. Unless you're tired of this camera, you could try with new, maybe borrowed, NiMH bats. Good luck
Jun 09, 2006 | Fuji FinePix 4700 Zoom Digital Camera
Fuji FinePix S5000 Digital Camera Logo
48 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
